Major electrical probblem?
Old May 5, 2010 | 01:25 PM
90goldhatch's Avatar
Default Major electrical probblem?
car wont start, i turn the igniton on and the only thing that pops up is the cel.
i hope someone can help me with this
Old May 5, 2010 | 01:44 PM
ef9er0's Avatar
Default Re: Major electrical probblem?
what codes are coming up?? people need more info if u want them to help
Old May 5, 2010 | 03:27 PM
6 ECT
8 TDC
10 IAT
the only reason why those are popping up though is because they're unplugged and there unplugged because i was trying different engine harnesses, even when everything was plugged up though the check engine light will be on and nothing else on the cluster
Old May 5, 2010 | 03:28 PM
if you want me to ill plug up everything and double check to see if its throwing any codes
Old May 6, 2010 | 09:57 AM
????help
Old May 7, 2010 | 11:19 AM
i forgot to mention my check engine light comes on and the main relay clicks when i turn my running lights on with the ignition off, the car does not crank please help me i think its a wiring issue what do you guys think
Old May 8, 2010 | 12:42 PM
anyone have a suggestion?
Old May 8, 2010 | 04:16 PM
wow 99 views and not a damn thing, it looks like im just gonna have to swap the dash harness
Old May 8, 2010 | 04:36 PM
fcm's Avatar
fcm
Old Fart
Start by doing a "bypass jump" connect a lead, [10-12 gauge] to the batt. pos.(+), unplug the starter lead at the starter motor, [thinner of two leads at starter motor and only one that "unplugs"], touch other end of jumper lead to starter terminal, BE CAREFULL, engine will crank even if car in gear, ign. switch off, so place transmission in neutral and set hand-brake.
Is car an automatic or a standard?
Other tests will depend on the above, "bypass jump" only tells you if the starter motor and starter solenoid are good. 94
jays35
Jun 17, 2014 02:31 PM
chubs93
Jan 29, 2012 03:37 PM
Red Ribbon Army
Jul 24, 2007 05:43 PM
LScivic_wpg
May 27, 2006 10:10 PM
dre000
Jan 19, 2003 01:36 AM
