MI 93 Civic Hatch Turbo 2000 OBO
So I'm selling my Old DD, I have to many cars.. It's current condition is not running.. When it was running it ran great and hard until the oil pump went out and it spun a rod bearing. The motor in it currently is a D16z6 Head on a D16a6 Bottom end with Vitara pistons, "Mini-me Vtec" with a homemade turbo kit.
Anyways I bought a new motor with plans to put it back to n/a stock but I don't have the time to do it. So here is the run down on the car, the rear struts are blown but I have replacements, the tuned ecu shorted out, so the car will come with a 92 Integra 5-speed ecu to run the motor that I got for it. The motor that will come with it is a d15b7. The car will come with a small system, it also has a 96 Integra dash/Interior swap and a 15" t.v in the roof. Car has no Power steering AC and Manuel windows.
What Needs work:
Motor/Bottom end replaced with the new motor
Rear quarters need fixed again "Previous owner"
Rear struts "have them"
Could use paint
Needs passenger side skirt
New parts:
Windshield
Si Hydro trans
XTD Stage 3 clutch
Headlights/Corner lights
Front wheel bearings
Front wheel studs
Front lower ball joints
Tie rod ends
Spark plugs and wires
Bosch Distributor
To sum everything up the car will come with everything to get it running with the new rebuilt motor, new trans/clutch, good ecu, Integra interior swap, System, set of used stock tires, set of drag radials mounted "on the car currently"
Call or txt 248-778-6265 names Joe
What Needs work:
Could use paint
New parts:
Windshield
Si Hydro trans
XTD Stage 3 clutch
Front wheel studs
Tie rod ends
Bosch Distributor
FlatBlackHatchbucket
May 27, 2007 04:28 PM
JFG Kevin
18
Apr 20, 2004 07:48 PM
TurboBumblBee
Feb 16, 2004 07:28 PM
