Throttle cable for ITB toda 4AGE 20v
Old May 5, 2010 | 09:58 AM
kaiba's Avatar
Default Throttle cable for ITB toda 4AGE 20v
Anyone know which correct throttle cable to use for Toda, OBX, 4AGE 20v itbs. I've tried using D16Z6 and 99-00 B16A2. Both would not open full throttle.
Toda
OBX
Old May 5, 2010 | 11:55 AM
CHEETAH's Avatar
Default Re: Throttle cable for ITB toda 4AGE 20v
need to use the b16a / ITR ... but it wont work just like that you have to adjust them (took me about 1-2 hrs of trying it back and forth. each screw adjusts each port and you have to get them to open up exactly by adjusting.
its been years since i;ve done this so can't remember the details but i do remember it was a pain. lost HP on dyno too cause one port wasnt opening up fully so had to keep adjusting at full WOT, then adjust at fully closed.
Old May 5, 2010 | 02:03 PM
killerpenguin21's Avatar
what chassis is it in?
ive had my twm's in an ek and now an eg and both times i had to cut the throttle stop off the back of the gas pedal to get 100% tps readings.
Old May 5, 2010 | 02:09 PM
kaiba's Avatar
It's going into a 94 Civic. That rubber stopper that connect to gas pedal, right. I though bout cutting it too.
Old May 5, 2010 | 03:19 PM
no not that.
i just put my twm's in a 92 eg using what i think is my old d16 cable. then on the back of the gas pedal, the part your foot pushes on there is a bug metal piece that hits the floor 2 inches or so before the pedal would. i just cut it off and it gives you well at least it gave me the last bit of travel i needed. you have to take the pedal out to do this.
on my old ek i notched a bunch of washers, and then jb welded them together in a stack to act as a spacer on the cable to give me extra travel, along with a few other mods.
Old May 5, 2010 | 08:26 PM
kaiba's Avatar
LOL. Got it.
ken-e
Jul 26, 2010 07:55 AM
slacks
Sep 20, 2008 09:49 AM
rasta420
15
Mar 15, 2003 05:38 AM
StinkyTofu
May 14, 2002 08:16 PM
