rear disc conversion from eg to eg help
Old May 5, 2010 | 06:42 AM
cehcivic15's Avatar
Default rear disc conversion from eg to eg help
what exactly all do i need from a rear disc civic to convert my civic, besides calipers and rotors and pads ofcourse. i have the prop valve already, do i need e-brake cables, and the whole trailing arm and brake lines or what can i use off of my drum setup that will still work?
Old May 5, 2010 | 08:45 AM
Imprezor's Avatar
Default Re: rear disc conversion from eg to eg help
I did the conversion (I have a 93 CX with rear drums stock) swapping the whole trailing arms with the e brake cables and brake lines.
I don't really know if it is possible/easy to do it without the trailing arms, e brake and brake lines.
But I guess if you live in the US it is no problem for you to find those trailing arms.
CivicSIR20
11
Nov 10, 2009 11:54 AM
sL3epy187
Suspension & Brakes
Sep 29, 2008 06:56 PM
cayman_hatch
Aug 26, 2005 10:58 AM
