idling cold lower than hot
Old May 5, 2010 | 05:28 AM
jazmie's Avatar
Default idling cold lower than hot
my setup:
b16a
skunk2 intake
super90 trottle 70mm
my prob:
when engine
cold condition,the idling about 800rpm
hot condition,the idling about 1500rpm
hot mean when i let the engine running long time or when i driving anywhere.
if i adjust lower at the trottle side...when cold time want to start my engine its very hard...need to push accelerate pedal a bit then can start.
any advise?
Old May 5, 2010 | 05:40 AM
T:rex's Avatar
Default Re: idling cold lower than hot
Im betting your fitv is stuck or the aicv has gone bad. Either one could cause this problem. You prolly have your idle set to 1500rpm and it drops to 800rpm when its cold because of no lube.
Old May 5, 2010 | 06:08 AM
jazmie's Avatar
with super90 trottle i no more use fitv.....the iacv i also already change it....but still same
Old May 7, 2010 | 09:36 PM
T:rex's Avatar
i dont know anything about super90 how does it regulate the fast idle? if it just bypasses the fitv and its been like that since the super90 that normal i guess.
Old May 9, 2010 | 05:57 PM
jazmie's Avatar
problem solved....after did my adjust tap pad and tighten my timing belt....
tq all bro's
Pezgoon
43
Oct 24, 2014 03:27 AM
reg_lus
Feb 21, 2014 12:49 PM
Thanks knightsport!
Jan 2, 2006 05:58 AM
StolenTeg
Nov 25, 2004 02:56 PM
typeeg
Jul 4, 2004 02:37 PM
