2005 Si power problem
ok, my friend says he was having problem with his 05 si going up hills and stuff he checked and he had no check engine light on, he took it to a mechanic and he said that maybe there was a problem with the tps, he found someone to let them borrow a whole throttle body from a k20 rsx and the car seem a lot fast now but the check engine light turns on sometimes and the idle is a little high (1200 rpm) he asked me how it is you calibrate the throttle body. is he using the right throttle body???
edit: he wants to know how to calibrate the tps sensor.
If the light turns on then get it checked asap, itll point you in the right direction.
https://honda-tech.com/forums/acura-integra-6/tps-sensor-issue-gsr-2234740/
AD_NAPCO
Honda CR-V & Element
Nov 8, 2015 08:17 PM
88si
Feb 28, 2009 05:27 PM
