car is bogging when im flooring it
hey will i have a bone stock 98 jdm b16a and the ecu im running is a p28 with a mugen chip
okay right now the problem is it bogs out when i floor it but when im driving most of the time it drives regular my car is running rich and before i use to be able to floor it and it would only lag at certain rpms..such as when i get pass 2500 rpms everything would be fine but now the more i floor it the worse it gets
any help would be great thanks in advance
any check engine lights? have you checked your ignition timing? have you ever changed the timing belt/water pump if you have you may need to check your cam timing? done any routine maintenance: plugs/wires/cap/rotor/fuel filter? If you can try another ECU.
i have a code 10 which is the iat and im using a obd2 manifold i always had that cel on my other cars never had this problem but as far as maintenance ive change the oil spark plug and the head was done at the machine shop the cam timing is on correctly and the ingition timing is advanced all the way
Its probably your fuel filter. Same thing happened to me. If you take it off and its hard to blow through you should replace it and it will probably take care of the problem.
carlosd68
12
Sep 28, 2012 08:07 PM
johnny090881
Jun 7, 2009 10:56 PM
