2000 ls wont start when is warm
Ok just need a little help ,i check voltage from the main relay to the pump and is there ,the fuel pump primes ,i got spark ,just installed new spark plugs like a week ago also new wires and when the car is cold starts normal ,oh before i forget it does have a code for a faulty cat converter ,dont know what else to check
change the main fuel relay, located up under the dash on the driver side, its about 3 inches wide, change that and problem solved ranges from 40-60 bucks depending on where you go. look for an import part specialist they will have it, it is about 120+ at the dealer
ej84dr
Jun 16, 2010 05:20 AM
slavagc8
15
May 26, 2009 06:17 AM
