back fire? rpm's bogging down?
Old May 4, 2010 | 12:56 PM
mrmoomoox's Avatar
Default back fire? rpm's bogging down?
i have a d16y7 soo when i open the throttle the rpms bog down and back fires but when i lightly open throttle it runs fine but when you open it up alot rpms wont move up past 2k and back fires..
any advice what it could be? from my knowledge it could be a dizzy problem
Old May 4, 2010 | 01:06 PM
1badteg's Avatar
Default Re: back fire? rpm's bogging down?
any check engine light? check the dizzy, plugs and wires. could be a lean/rich mixture and is causing it to backfire and miss. hows your timing? are you boosted? answer those and maybe some people on here can answer you better
Old May 4, 2010 | 01:14 PM
bizzerk89's Avatar
check cam and crank sensors really well.. i had this problem once, but it wouldn.t go past about 2700 rpm and it was slow like wouldn't break 20 mph. it was explained that one or both of the sensors have gone bad so the computer goes into "limp" mode, guessing the timing, but most of the time it guesses wrong.
Old May 10, 2010 | 07:42 AM
mrmoomoox's Avatar
alrighty thanks alot guys
decon
Nov 11, 2012 10:55 AM
MMMGIRL
Apr 22, 2012 10:21 AM
aziaticvang
Apr 25, 2009 08:51 AM
ShawnbobHatch
Dec 30, 2008 12:00 PM
89efhatchcrap
10
Jun 10, 2006 04:48 PM
