The Journey of a DeatschWerks Injector
Old May 4, 2010 | 12:54 PM
Deatschwerks's Avatar
Default The Journey of a DeatschWerks Injector
This blog was written by the President of DeatschWerks, David. He has a monthly blog that can be found here: The DeatschWerks Tech Blog
Please give us your feedback in the comment section of the blog page!
Chris
By David Deatsch
When your shiny new box of DeatschWerks injectors arrives at your door, few realize their journey consisted of much more than a ride on a UPS truck. Post production testing at DeatschWerks is just as important as the magic and love we put into each injector during the production process. Before injectors are put into sets, a battery of tests are performed and only the best make the cut. Our staff works hard to to continually develop and improve what is already the industry leading injector testing and quality assurance program. It is a lot of extra work but it is all worth it to ensure flawless performance for our customers from the first crank of your engine.
Coil Testing – Ohm testing is where many shops stop but it is just the beginning for us. In addition to the basic ohm test, we test for direct shorts, voltage draw, and latency. Our newest coil test is an LCR based binning procedure which combines impedance, inductance, and resistance values of a coil to classify injectors into 3 different categories (bins). These bins are then separated and never mixed so only injectors with the closest coil characteristics will make it into the same set.
Spray Pattern and Atomization – Proper spray pattern and atomization is analyzed visually on the flow bench. The spray pattern is observed at a wide range of pulsewidths and rpms so that the injector is assured to perform well under all engine conditions.
Static Test - We perform the static test a minimum of 3 times on each injector to ensure consistency. In addition we only flow test using the best equipment which is calibrated daily and operated by experienced, full-time, DeatschWerks trained employees.
Dynamic Test – We have been using dynamic testing in accordance with SAE guidelines since day one over 5 years ago. Every set of our injectors is balanced for static flow rates, dynamic flow rates, and coil response.
Injector Matching - What good is all this testing if we don’t put it to good use? We use all the data we collect to make the best sets possible. We match injectors for static rate, dynamic rate and coil response. We put them in sets with less than 2% variance in each of those 3 categories.
QA testing – The last step is putting the injectors into matched sets so we’re done, right? Oh no, we pull 10% of all boxed injectors off the shelf and flow test one more time. Why? quality control, thats why. We go the extra mile to provide our customers the best quality available.
The report – A personalized flow report with every set… it’s a DeatschWerks exclusive. No other company gives you as detailed information about your specific set of injectors as we do. In addition, we provide the data on a colorful, easy to read report.
Old May 4, 2010 | 02:03 PM
2k.civic.si's Avatar
Default Re: The Journey of a DeatschWerks Injector
Hey! I bought injectors from you long long ago when you were selling them on ebay. Great guy great injectors!
What do you charge these days to make a set of oem injectors 550cc?
Old May 4, 2010 | 02:24 PM
PM'd
Old May 4, 2010 | 02:51 PM
92redhatch's Avatar
Are these injectors like the Id or fic injectors?
Old May 6, 2010 | 10:47 AM
boostedcivicsir's Avatar
Mr. Badwrench
https://honda-tech.com/forums/drag-racing-36/new-rules-vendors-2767661/
but those rules only apply 1- in the drag section - if you are a paying vendor. please contact an admin about becoming a vendor.
boostedteg4dr
Nov 30, 2013 01:17 PM
done
Apr 9, 2008 02:44 PM
Panoply
Jul 19, 2005 01:37 PM
joeyitr309
Apr 22, 2005 08:07 AM
Mr.Death
Jan 30, 2005 08:23 AM
