rear end sqeeks
oka i put 17's on my car today and before my rear end never use to sqeaks and ever since i put on my 17's on and it sqeaks when i turn a corner or bounce a little bit...its on the pass side 95 civic, the tires do not hit the body panels i already checked the clearence and like i said it didnt do it till i changed my rim size, the car is dropped with skunk 2 springs and tokico shocks i use to have the rimes on before and it didnt do it and now it does....any help???
grab a friend and have them push down on the trunk and make the car bounce to replicate teh squeak.
with your hand "feel" each part on the pass. rear end. trailing arm, spring, lower control arm...
the tip im trying to give you is that sound is a vibration. so that squeak you'll actually be able to feel with your hand.
