oil leaking
SO I have a 94 eg coupe that i just bought friday. and the guy said he did a swap. the motor is a d15b and it has a block plate where the vtec solenoid usually is on the head, but it leaking oil all over the tranny and stuff.
Where can i get a gasket for that at?
Considering that you have full oil pressure going against that plate, you may not be able to really seal it unless you put on the vtec spool valve (solenoid) with a new spool valve "filter" (it's a complex o-ring with a mesh screen in one section of it). You could try taking the block-off plate off, clean both surfaces thoroughly & seal with HondaBond, but no guarantee. Let it sit for over 3 hours before starting the engine to allow the HondaBond to cure properly.
It is most certainly not plug and play. You need a VTEC ECU with VTEC wire, a VTEC head, VTEC pressure switch and VTEC solenoid. I think he means just buy the solenoid and slap it on. It'll solve you're problem without tons of work in a mini me swap
oh kk i see. well i found a solenoid on ebay for like $50 bux shipped.
http://cgi.ebay.com/ebaymotors/HONDA...Q5fAccessories
i noticed it had 3 bolts and my plate only has 2. will that fit my d15b?
