Putting alarm in passive mode to arm turbo timer?
Old Sep 11, 2002 | 12:44 PM
VTEC-DA's Avatar
Default Putting alarm in passive mode to arm turbo timer?
I just talked to the guys at Inline Pro (shop in northern Va for those who dont know) about installing a turbo timer for me. The guy said that most likely, I would have to put my alarm in passive mode for the turbo timer to function correctly? What does this mean? I have the Viper system, can it be put into passive mode?
Old Sep 11, 2002 | 01:43 PM
STK B16's Avatar
Default Re: Putting alarm in passive mode to arm turbo timer? (CivicthatsBlack)
Passive mode is not gonan work.. ur car will just unlock while the engine shut off.. You cannot arm a car when the ignition is on. YOu have to make a relay to make the alarm think that the car is off. and that way you can arm your car.. Or what you can do is not have a Starter Kill.
Old Sep 11, 2002 | 03:40 PM
VTEC-DA's Avatar
Default Re: Putting alarm in passive mode to arm turbo timer? (Json79)
What kind of relay do you mean? What kind of realy would make the car think the alarm is off? There has to be people on here with turbo timers and alarms?
Old Sep 11, 2002 | 08:45 PM
twogengsr's Avatar
nope you dont need to do all that all you have to do is move your yellow ign wire from the alarm to the accsory wire and it will arm and lock with your car running on the turbo timer
Old Sep 11, 2002 | 08:47 PM
twogengsr's Avatar
oh yea if you dont want to mess with it you can bring it by myu shop in laurel md and ill do it for you for like 30 bucks its a car audio shop called audio video solutions 301 953 7242ask for adam
Old Sep 14, 2002 | 08:10 PM
STK B16's Avatar
Default Re: Putting alarm in passive mode to arm turbo timer? (twogengsr)
yea it will arm and disarm.. but u have to remember when the accessroy wire lose that + pulse it will unlock the doors.and if there is power going through the igniition for the alarm u cannot arm the car.
Old Sep 16, 2002 | 06:35 PM
twogengsr's Avatar
no thats not true , you missunder stood what i was saying it will lock the doors when he turns on the car just like half a second later the ignition wire will get 12v when the car is started and the acc wire gets 12v it will start lock right up you have to use the starter kill yellow wire to true ingnition and the yellow wire comming off the alarm brain would be the wire going to acc
Old Sep 17, 2002 | 09:47 AM
The Auto Toy Store's Avatar
When you istall aturbo timer you need to bypass sensors on the alarm (ie: impact, current sensing), most current Viper alarms can be programmed for this or a good install facility can do it for you without having to put your car in passive mode. Not all installers are equal look for one with at least a few years experience with the products that you use.
mrm1ke02
Audio / Security / Video
Sep 18, 2007 11:00 AM
Boostless97Lude
Nov 4, 2005 12:36 PM
iRIDEdumped
Apr 29, 2005 06:34 PM
boostincoupe
Jul 8, 2003 07:19 AM
Mase
Apr 3, 2002 08:54 PM
