B16 has no spark but power to dizzy
Old May 3, 2010 | 02:52 PM
JDMEMone's Avatar
Default B16 has no spark but power to dizzy
K so i got my track car back running. it is a em1 with a b16 i did a wire tuck and a manual power steering box. so when put the motor back in and wire'd it all up it fired right up with now problems. so i took it for a drive and all of a sudden the car just turned off. So i have check the spark and didnt get any so i took of the dizzy cap ( couldnt get the rotor off so i broke it and now im running to get a new one) and i put test light to the two screws inside the dizzy and they both lit up. so i have power to the dizzy what else could it be? thank you guys in advance!
Old May 3, 2010 | 03:11 PM
Former User's Avatar
Default Re: B16 has no spark but power to dizzy
Any CEL codes? Does the fuel pump prime?
Start by checking the ground wire attached to the thermostat housing.
Old May 3, 2010 | 03:39 PM
JDMEMone's Avatar
yeah i have a fuel pressure gauge and it primes to 45psi. the ground to the thermostat houseing some where else... does it matter, or does it have to be grounded there?
Old May 3, 2010 | 04:42 PM
CEL codes?
Start by checking the coil and ICM inside the distributor.
Old May 3, 2010 | 05:24 PM
JDMEMone's Avatar
k so i redone the grounds with no luch then i put a light tester on the ICM and i only get power out of the black/yellow and the yellow and green. i even put a ground directly to the thermostat ground. and nothing. i do not have any cel's. RonJ thank you so much for helping i will check the rest i am going to pick up a ohm meter right now
Old May 4, 2010 | 04:28 PM
JDMEMone's Avatar
k so i borrowed my brothers gsr distributor and the bastard started right up with no problems. how do i go about checking if its the coil or the ignighter?
gringo7718
20
Jun 3, 2012 02:45 PM
junior_tm
Aug 2, 2009 06:32 PM
nineohnine
Jul 13, 2009 05:36 PM
philkehn
28
May 26, 2006 09:40 PM
prjctCIVIC
Mar 22, 2002 07:51 AM
