underhood fuse box fuses stay hot after ignition is turned off....
Old May 3, 2010 | 01:46 PM
sins's Avatar
Default underhood fuse box fuses stay hot after ignition is turned off....
ok like the title states the underhood fuse box in my 4th gen lude stays hot after i turned the car off and i know it shouldnt be that way, so could anyone point me in the right direction into whats causing this problem thanks in advance...
Old May 3, 2010 | 04:33 PM
Enzo15's Avatar
Default Re: underhood fuse box fuses stay hot after ignition is turned off....
I kno the problem to this. The problem lies in the fact that your battery and alternator are directly hooked up to the fuse box. So because of this it is normal for for the fuse box to remain hot at all times. Its the same in every car. Always. Nothing is wrong.
Old May 3, 2010 | 05:34 PM
duanes's Avatar
Do you mean hot as in - electricity is there, or hot as in "Ouch, that bad boy is hot!" ?
Old May 4, 2010 | 02:32 AM
sins's Avatar
Hot as in electricity
Old May 4, 2010 | 07:23 AM
integra15's Avatar
see post 2
El3ments
Jun 2, 2008 11:55 AM
ziggen243
Jul 19, 2007 11:41 PM
sikteg2172
Feb 18, 2007 04:09 PM
EliteRacer05
Aug 5, 2005 10:01 AM
