synthetic oil in a d16?
Old May 3, 2010 | 06:57 AM
markspan6243's Avatar
Flattery Will Get You Everywhere
Default synthetic oil in a d16?
ok so i was thinking about running some synthetic oil in my del sol. it has the original d16 in it and im pretty sure it has never had synthetic oil ran through it. ive heard from my friends dad that its not a good idea to use synthetic oil in that old of a car (mine is a 1994). what do you guys think? should i not worry about using synthetic, or does it not matter about what kind of oil it is? thanks for the input!
Old May 3, 2010 | 07:03 AM
96hb's Avatar
Default Re: synthetic oil in a d16?
I wouldn't do it. If your engine is high mileage, introducing synthetic can cause more problems with leaks and burning. I tried it once in my car and it didn't like it at all. Besides, it's just a d16. Any quality dino oil will be more than enough protection.
Old May 3, 2010 | 07:07 AM
shoklid's Avatar
wow, i hate the way ppl act like synthetic is not petroleum. lol lol u can mix it together on and off and wont hurt anything. only thing synthetic can do is show u where ur car is leaking oil that u have never seen b4. bc it is more slippery to the touch will leak in places u nvr had some
redef90si's Avatar
how many miles on your motor?I'd do a compression test,see if it's healthy then go from there.If it's burning oil or needs valve seals or piston rings no point in spending more money on a "wounded" engine,best of luck.
Old May 3, 2010 | 07:12 AM
96hb's Avatar
That was kindof the point of my post. I put synthetic in my old, tired d16, and it started leaking more. I don't like expensive oil leaking out onto my garage floor, so I went back to dino. Why the hell would he need synthetic anyways? Judging by his signature, he's not boosted, doesn't have high horsepower, so why change?. My d16 has treated me well over 220k miles on nothing but dino oil, except for that short stint on synthetic.
Old May 4, 2010 | 09:05 AM
its not that i need it i was just wondering in case i wanted to try it. my engine just turned over 104xxx miles, and not to toot my own horn, but my car runs like a top, and there are no leaks, burns, ticks, or any other noises with it.
Old May 4, 2010 | 09:33 AM
96hb's Avatar
Well then just try it and see what happens.
Old May 4, 2010 | 10:13 AM
EJeff8's Avatar
I'd just go high mileage personally. It binds much quicker to metal than ordinary oil, you'll see your oil pressure gauge jump up the minute you start the car. It's formulated for cars over 75,000 and has never given me trouble. It's "synthetic" in a sense as well.
Old May 4, 2010 | 10:27 AM
titi_vtec's Avatar
if i was you i dont doit, because that oil is taking more time to get burn and the oil will be the same for long time on your engine and that will put the inside of your engine dirty, just continuos with the normal one that is more safely, one time i did that to another civic that i got and when i open my oil paw it was dirty as fu... and i never see it like that, good luck with that
Old May 4, 2010 | 01:51 PM
TheJGB3's Avatar
I switched over from dino to 5W30 full synthetic on my 2000 EX at 104,000mi. (after performing two auto-rx treatments). My engine ran like a top before, with no leaks or burning, and it still does (at 115K now).
more info on auto-rx
http://www.auto-rx.com
Old May 4, 2010 | 01:58 PM
Wdpfreak145's Avatar
I am now seriously dumber for having read that post. Dear lord.
Old May 4, 2010 | 04:17 PM
ejprimo's Avatar
save your money. go to oreiley's and stock up on their conventional oil for $2/qt.
Old May 4, 2010 | 04:23 PM
b20hatchek's Avatar
why dont you seafoam the motor to see how much carbon you burn, i got a couple more numbers on my top speed and better mpg on my supra and my b20 ek, you dont have to change the oil to get better performance or reliability from the motor
Old May 4, 2010 | 04:43 PM
vwtohonda's Avatar
I Switched over 3 months go in my d15z1 with 134k mi, and it runs fine and doesn't leak, actually runs smoother IMO
Old May 4, 2010 | 04:47 PM
b20hatchek's Avatar
yeah it all depends on the motor and how it was treated in the past
Old May 4, 2010 | 04:51 PM
98civdx's Avatar
Master Detailer
I run synthetic blend in my d16 and it does just fine, i have ran full in past but not really worth the $2 or so more a quart to me.
Old May 4, 2010 | 04:57 PM
vwtohonda's Avatar
Yea i recon... I put in AmsOil full syn, just to see if there is a difference... Works great! Looks clean as a whistle everytime I check it and Only one way to find out OP, switch it over and see what happens, if it leaks that just means it started sooner then later... Go for it.
Old May 4, 2010 | 04:59 PM
98civdx's Avatar
Master Detailer
I should have put that. Switch and keep a close eye on it, if it burns faster the usal or leaks switch back to the regular stuff.
Old May 4, 2010 | 05:17 PM
kaboom954's Avatar
My del Sol does and needs all of thee above lol
Old May 5, 2010 | 05:59 AM
so someone tell me how to do seafoam. i heard good and bad things about that too. i remember hearing that someone did it, and it really ****ed up their car
Old May 5, 2010 | 06:48 AM
shoklid's Avatar
how can seafoam hurt anything. i failed emissions went to store and put seafoam in my car took it back to the station 50 miles later and it passed with flying colors. i recommend seafoam . def makes a car run alot cleaner so that = better in all ways .
Old May 5, 2010 | 07:00 AM
b20hatchek's Avatar
hells yeah seafoam, ok how to: alright go to oreillys and buy the 9 dollar can, drive home wait! you need to drive there first and pay for it then drive home! lol alright seriously open the can up and take off the vaccum hose going "to" the brake booster and put the hose in the bottem of the can then have someone start the motor and and slowly open the tb by hand but just a little, your motor is gonna sound like **** for a while but it'll be fine and your deff gonna have alot of white smoke come from the exhaust, its fine. now if the motor dies before your done just start it back up again and keep going untill the can is empty and then drive the car untill the white smoke is gone and bam! your done and youve gotta cleanish engine and from now on keepgetting gas from staions that have ethonal in the fuel oh and dont forget to put the vaccum hose back on the booster
Old May 5, 2010 | 08:25 AM
newtron63h's Avatar
i would not use it like others have said mostly because it tends to make small leaks worse. also there is only 1 reason to use synthetic in a street car and that is because you can go longer between changes(unless the manufacturer calls for it)............ it honestly does not have any other advantages in a street car. a good quality conventional high mileage oil will do EVERYTHING an older DD needs it to do and then some.
Old May 5, 2010 | 08:31 AM
newtron63h's Avatar
seafoam is good, about the best you are gonna get from a parts store. but a better one is BG 44K, most dealerships use it. and its easier than seafoam(not that seafoam is hard) but you just put it in with a full tank and go.
Old May 5, 2010 | 11:02 AM
mikej94civex's Avatar
x2!!!!! pennzoil 5w30 high mileage with a can of engine restorer every other oil change and ur set! my z6 ran soo much better
after the FIRST oil change, and still is runnin good, wayy better than before!
Pennzoil (non-synthetic) 5w30 high mileage oil ftw!!
btw i tried mobil one synthetic and it made my honda tick louder, and i smoked a bit, which was weird cuz before that
it NEVER smoked, soo imo don't use synthetic man
