why do i keep smellin burnt clutch?
Old May 2, 2010 | 06:49 PM
jdmstyleEJ6's Avatar
Default why do i keep smellin burnt clutch?
okay i was just wonderin why i keep smellin burnt cluch is m clutch goin out. also im not ridin the clutch
Old May 2, 2010 | 06:55 PM
DOUBLExDEUCEx22's Avatar
Default Re: why do i keep smellin burnt clutch?
does it happen when you like drive fast and get the rpms like around 6 or 7? cuz that has been happening to me lately
Old May 2, 2010 | 07:22 PM
yes. ne1 have a answer 4 me
Old May 2, 2010 | 07:23 PM
DoubleEx's Avatar
yes its starting to go out dude.
Old May 2, 2010 | 07:27 PM
EJeff8's Avatar
The higher you go in RPM, the easier it is to tell if it's bad.
This should make it obvious.
Old May 2, 2010 | 07:48 PM
thanks for yalls help
Old May 9, 2010 | 01:22 PM
is it bad that i smell burnt clutch
Old May 9, 2010 | 02:12 PM
fleabag's Avatar
I think it should be obvious that there is a problem. Either the clutch springs are worn, the pad is worn, or both..
I wouldn't expect to be able to drive the car much longer before the pad completely goes.
Old May 9, 2010 | 02:24 PM
Noel L Eguia's Avatar
The clutch is probably worn out.
What does burntt clutch smell like.
Haha.
Old May 9, 2010 | 02:27 PM
fleabag's Avatar
Haha.
Is probably the worst automotive smell you could imagine. When I burned my clutch a bit one time, the smell was so strong that after I got home, I could still smell it where ever I went and it didn't come out until I took a shower. I think it smells the same as burnt brake pads as they should be made of the same material.
Old May 9, 2010 | 03:45 PM
DoubleEx's Avatar
smells like sulfer, rotten eggs. Maybe a burning fart smell.
Old May 9, 2010 | 03:55 PM
Linked's Avatar
at times when i'd hit high rpms, i'd smell a burnt rotisserie smell after i idle afterwards.
and no, no one was BBQing
Old May 9, 2010 | 04:13 PM
fleabag's Avatar
I think part of the reason why you'd smell the clutch at high RPMs is because hondas have weak clutch springs in order to make city driving more pleasant. If you want performance, you'll need a stiffer clutch.
HondaLuv3r4Life
Honda Civic (2006 - 2015)
Jan 24, 2019 08:24 PM
NinjaTech
Aug 1, 2005 01:44 PM
Flux
Nov 26, 2003 11:25 PM
jeebusm3
May 5, 2002 12:20 AM
