Question about OEM badges
Old May 2, 2010 | 02:51 PM
twentyhurtz's Avatar
Default Question about OEM badges
ok, so i'm sure most of us have broken an emblem or knocked one off, etc.
While waxing my integra, i knocked off the front emblem, also everyone knows there is 2 holes behind the emblem. Also if you have knocked one off you know it sucks to glue the emblem back on- because the 2 prongs or whatever is on the emblem breaks off.
My question is, does the oem emblems have 2 studs or prongs that clip into the two small holes- or is there just two studs to keep the emblem aligned?
I have tried to replace the emblems- because gluing sucks, but when i try to find OEM replacment emblems, they have double sided tape and i'm pretty sure the originals did not.
So.... can you get the REAL oem emblems still or do you have to get the replacement OEM emblem (in a honda parts bag) that has the double sided tape?
Old May 2, 2010 | 07:04 PM
mouab18c1's Avatar
Default Re: Question about OEM badges
It sucks but then those Stupid things aint cheap from the dealer either. What I did was I jacked my buddies H emblem off his 93 Civic Coupe which has the two studs behind it and used electrical tape to tape around each one individually to make them thicker. Once I did that I just aligned up the two studs to the wholes and pushed it in. Havent had an issue with it at all and its easy to pull back out. Again this is for the front one only.
Old May 3, 2010 | 05:49 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Just use 3M emblem tape. There's nothing wrong with it, and it will come off relatively easily in the future. When I had emblems I cut narrow strips of 3M emblem tape (very thin gray foam tape, not that thick white stuff) to hold the emblems on and it worked fine for several years. Usually the tape will just rub off if you have to remove it, or at worst you might have to use a little Goo Gone to remove the residue.
Old May 3, 2010 | 07:04 AM
ah, as i feared... tape..
i was hoping to find just an emblem i could snap on and be done, but so be it i guess.
Old May 3, 2010 | 07:06 AM
Spawne32's Avatar
as far as i know they are supposed to have push clilps and double face tape on the back like the one on the trunk, i ordered mine from parts.com for like 25 bucks
Old May 3, 2010 | 07:58 AM
1993-eg1's Avatar
the oem ones that i got for my teg had the tap and studs on them when that came on but they where rear badges
Old May 3, 2010 | 09:03 AM
Community Builder
There should be little plastic clips that fit in the holes on the bumper that help hold the emblem in place. I never trusted those by themselves, though, so I used the emblem tape in addition.
h2392si
May 26, 2005 12:39 PM
ev0luti0n
Feb 19, 2004 07:08 PM
eddiecut
Mar 26, 2003 07:00 PM
