b16a into 91 civic hatch with hf harnesses
i have a 91 civic hatchback dx with 91 crx hf engine and underdash wiring harnesses. I'm swapping a obd0 jdm b16a. I swapped both harnesses already, swapped the b16a already. Do I have to switch wires on any of the plugs on the engine harness? I cranked the car and it would just turn, but no startup. Was wondering if some plugs wires needed to be switch? Is there anything else that I needed to do? Please any inputs would be appreciated! Thanks.
you don't need to switch any wires as long as both the engine harness and the chassis harness are from the HF
are you getting a Check Engine Light? codes?
does the fuel pump turn on when you turn the ignition on?
timing is right fellas. dang, this is giving me a headache. i feel like giving up and selling it now. anything else i should check and do??????
check for spark and check for gas or get enginge choke like for dirt bikes and spray in the throttle body open then crank if it sarts its the gas
have spark on the dizzy plugs. fuel pump primes, has gas at fuel rail. fuses are good. PS have the squre white plug, one big plug, and small plug. DS has one big plug and resistor box plug.
Well same thing is happening to my friends car, and we have checked everything just like you have, the only conclusion we've come to now is that he had a shitty ecu. We still havent tried a new one yet though.
thanks guys...finally found it was the freakin injectors...change them and fired right up...thanks alot fellas............
WhiskeyHammer
Dec 31, 2018 06:49 AM
tek_civic
May 13, 2006 03:50 PM
civichopeful
Aug 2, 2002 01:53 AM
