How do you put on a regular ext. coil???????
Old May 1, 2010 | 11:35 PM
si_motor_spt's Avatar
Default How do you put on a regular ext. coil???????
Hey all, my moms prelude has the stock external coil, unfortunately, when i worked on it today, i just took off the coil wire and the plastic on the coil itself, where the coil wire would plug onto, kinda broke into fragmented pieces(i guess brittle from the engine heat). i priced a new oem coil and its like almost $100, my question is, can i put in a regular msd external blaster coil? i looked at the plug on the oem coil and theirs 3 wires and the msd coil just has the + and - on the coil, can anyone help me to get thisd to work, Thanks......
Old May 2, 2010 | 12:40 AM
kornkid21792's Avatar
Default Re: How do you put on a regular ext. coil???????
on msds website it gives you full shematics of how to wire them
Old May 2, 2010 | 01:26 AM
92bluepreludeSi's Avatar
The two big wires go on the positive and small wire on negative
Old May 2, 2010 | 01:45 AM
BlackAlbumKoupe's Avatar
Bumppppp
Old May 2, 2010 | 12:49 PM
Thanks for the info guys, i'll try that and get back to u guys, mahalos
Old May 8, 2010 | 01:23 AM
MikeLuder's Avatar
do NOT use the MSD blaster Coils unless your using a MSD ignition box. Trust me, you'll burn out the Ignitor in the distributor. Buy a New HONDA Coil. or FAIL
Old May 8, 2010 | 06:09 AM
HondaPartsHero's Avatar
Technical Hero
or grab one from a junk yard
Old May 8, 2010 | 08:58 AM
Apex1972's Avatar
I just removed all my msd stuff the other day. the sci box failed and I was gonna sell the coil to someone on the 3rd gen forum. I guess I wont do that cause I dont want anyone to burn the ignitor out just so i can make 20.00
Old Oct 29, 2020 | 06:44 AM
Terry Starkey's Avatar
i have a couple questions about my 1993 honda prelude if u have a minute
Old Oct 29, 2020 | 09:54 AM
snobordboy's Avatar
Moderator
This doesn't work like FB.... If you have a question start a thread. This one is 10 years old, and the user that you quoted hasn't been on the site in the last 3 years.
r1ch1e
Aug 30, 2007 11:12 AM
Rodzknight
Jul 3, 2006 01:02 PM
juicedh22
Oct 9, 2004 05:45 AM
DANG YO
Nov 21, 2003 09:40 PM
