builtt race motorrrrrr!!!!!sleeved!!!1
hey i got for sale my ls/vtec turbo build , the motor is fresh never ran yet, im selling due to funds for another build and street bike ..... i got pics just ask ill try to get some up soon... trade for cars or bikes welcomed.......
head___
jdm b16 head 3 angle valve job milled 3 thousands and port cleaned up
skunk 2 pro series valve std
skunk2 pro seires springs
skunk 2 retainers
skunk 2 pro one cams
skunk 2 por series cam gears...
ferra seal and bronze guides
voctor x manifold
aem fuel rail
blox regulator
fic injectors 850cc w/resistor box
white powder coated valve cover with 10-an line catch can steup and maroso can
oem seal entire head
block__
b18a1 block golden eagle sleeved 81.5 mm bore
manley h beam rods
manley 9:1 compression pistons
acl race bearings and thrust washers
arp main studs
golden eagle head studs and head gasket
polished ls crank
type r oil pump
type r water pump
oem timing belt tensioner and belt
ctr n1 underdrive pully
earls oil feed line and ls vtec kit
oem main seal
oem oil pan tapped with 10-an return line
oem thermostate
tran___
gsr trans rebuilt with syncrotech carbon kit
new oem bearings
oem axle seal
m factory lsd
and honda bond to seal her back up
as well with entire motor
turbokit____
custom made ic pipe ek,eg 2.5" aluminum
3 ply ic boots, t bolt clmaps
tial 50 mm bov silver
synapse 50mm wastgate
afi tubular ram horn manifold
afi down pipe
garret 60-1 p trim t3 .70a/r
treadstone front mount good for over 750 hp
everything cost me
head-4000.00
block-3200.00
trans-2000.00
turbo kit-2600.00
almost 12000.00 total taking offers will like to sell whole if possiable but in want to part as in like just
long block(6500.00),
trans(1500.00),
turbo kit(1950.00),
long block and kit(8000.00)
,kit and trans(4200.00) ,
ill do but not disassemble motor or parting kit...thankss make offers slighlty neg on package deals.....
im sure im forgetting more but any questions please email,pm or text, 732 966 5732
quickest response will be text
head___
skunk 2 retainers
voctor x manifold
aem fuel rail
blox regulator
block__
manley h beam rods
arp main studs
polished ls crank
type r oil pump
type r water pump
oem main seal
oem thermostate
tran___
new oem bearings
oem axle seal
m factory lsd
as well with entire motorturbokit____
afi down pipe
everything cost me
head-4000.00
block-3200.00
trans-2000.00
turbo kit-2600.00
trans(1500.00),
turbo kit(1950.00),
5th element
Jan 29, 2014 02:09 PM
gsrwanted
Dec 29, 2008 06:36 AM
gsrwanted
Nov 15, 2008 07:18 PM
