92 GS with JDM B18C (Type R) and Chipped USDM P28 ECU, throwing codes..
Old May 1, 2010 | 05:27 PM
Opo's Avatar
Opo
Icon3 92 GS with JDM B18C (Type R) and Chipped USDM P28 ECU, throwing codes..
K first of all the car is a:
92 GS
JDM B18C (Type R)
JDM S80 transmission
USDM P28 ECU chipped for the JDM B18C (Type R)
On a highway drive home today my car threw 3 codes:
20
22
36
You can see the YouTube video here to make sure I'm reading these codes correctly:
http://www.youtube.com/watch?v=KcagHN7PNdc
I need some advice as to where I should be looking for how to fix these codes.
According to this:
http://g2ic.com/tegtips/engine/13.html
Code 20 = Electronic Load Detector
Code 22 = VTEC System Malfunction
Code 36 = UNLISTED!?!
I found code 36 on this list:
https://honda-tech.com/forums/acura-integra-6/ecu-abs-codes-here-978933/
Which says code 36 = traction control found on JDM ecu's
But my ECU is clearly a rectangular USDM P28 ECU running a JDM B18C (Type R) so I guess maybe that could still cause it to throw code 36?
It is really weird because the car runs fine engaging VTEC and disengaging VTEC while revving through gears fine, but it seems to throw all 3 of these codes every time I rev it high for more that a few seconds and it doesn't seem to matter whether VTEC is engaged or not.
All 3 codes go away if the car is turned off and restarted again.
I have no heavy equipment in my car, the car doesn't even have speakers right now... never mind subs/amp etc...
Please direct me where to start looking in order to correct these problems, I have searched a lot on code 20 but have found very little information, none with solid answers.
Old May 2, 2010 | 02:06 PM
Opo's Avatar
Opo
Default Re: 92 GS with JDM B18C (Type R) and Chipped USDM P28 ECU, throwing codes..
bump
civic93@8psi
Mar 16, 2009 06:21 AM
butch11a
Engine Management and Tuning
Oct 17, 2008 04:33 AM
si vtec ftw
Apr 7, 2008 08:33 AM
Problemo
Mar 13, 2006 01:26 PM
CivicEx95
May 9, 2002 03:22 PM
