turbo em1 build pics/dyno...
..600+whp e85 turbo EM1 daily driven build..
motor set-up from 2004
84mm rs sleeved gsr block
knife edge crank
je 9:5.1 pistons
eagle rods
b16 head
crower springs and retainers
itr cams
victor x intake manifold
68mm str throttle body
golden eagle fuel rail
id2000cc injectors
nrg fuel cell
dual bosch 044 fuel pumps
honda s300
custom top mount turbo manifold and 4" dp
precision 6262 billet turbo t3/.82
garrett backdoor intercooler
precision 46mm wastegate
tial blow off
full 4" to 3" apexi world sport exhaust
itr tranny / comp clutch twin disc
driven at least 4-5 days a week with car seat in back
project pics from start to finish
..made 580whp off wastegate w/15lbs spring.. (still have upload picture)
heres one i have now 520whp off 15psi spring
22 psi 639whp/412tq ...tune was done by mike angel, with full exhaust on e85
knife edge crank
je 9:5.1 pistons
eagle rods
b16 head
itr cams
id2000cc injectors
nrg fuel cell
honda s300
tial blow off
Dun car looks awesome. Fuel system and everything looks real clean. Good luck at the track. I still need to send that you that charger for the odyssey battery.
thanks brian, all the fittings and lines turned out real good with no problems. still have to send you the extra fittings i have...ill hit you up this week for a regulator, bosch pump and some fittings and lines..
UPDATE:::: car made 810hp on 28lbs...still on the same turbo...6262. best time at the track 10.80 @ 135 with no vtec, first time out. hopefully we'll get the car into the low 10s high 9s soon..
will post pix and video later
