Harness compatibility
Old May 1, 2010 | 02:47 PM
Weifast's Avatar
Default Harness compatibility
Hey guys, got a 99 b16 sir2 motor in my 2000 hatch right now. Im swapping in a 2000 GSR motor. I have the engine harness, but we're missing the ECU harness going from the ECU to the engine harness. I know the 2000 GSR is obd2b, but I'm not sure if the 99 b16sir2 is obd2a or obd2b. Does anyone know if it'll plug up or would I need to go looking for the ECU harness for the GSR? Thanks.
Old May 1, 2010 | 03:53 PM
canadaek's Avatar
Default Re: Harness compatibility
what are you running for an ecu now? you can't use the teg harness in your hatch there a 2 piece design your civic is 1 piece your best bet is to find an obd2b gsr ecu and use your b16 harness and just add the wire's for the intake butterflys or use a obd1 ecu and a jumper harness.
Old May 1, 2010 | 06:04 PM
98civdx's Avatar
Master Detailer
unless jdm is different, 96-98 is obd2a 99-00 is b.
as he siad use your harness and add the proper things to it.
Old May 1, 2010 | 06:15 PM
xero_xero's Avatar
you will need the ecu harness from a GSR 96-2001 and matching ecu. desnt matter about the rest... below is the plugs for ecus to properly match what you buy.
Old May 1, 2010 | 06:20 PM
98civdx's Avatar
Master Detailer
You cant use a dc harness in 96-00 they are 2 peice 96-00 is 1, they do not mix.
Old May 1, 2010 | 06:26 PM
xero_xero's Avatar
Be clear.
you can use any Integra DC4 1996-2001 GSR harness. your ECU must match your harness type whether it be obd2a or obd2b. BE AwARE that 2000 and 2001 GSR ecus have immobilizers.
You can also use any 1992 harness or 93-95 ex/si harnesses for the ecu and use an odb1 GSR ecu. since the harness is a 2 piece design, it will still be compatible with the engine harness already installed.
Old May 1, 2010 | 06:59 PM
Weifast's Avatar
Hey guys, the ECU I have is a 2000 GSR OBD2b. I'm trying to BAR the engine in my 2000 hatch. The car is at the shop right now and we're done for the day, I was tired, so I'll be back at it on monday. I already got the immobilizer removed from the ECU and installed a dummy chip in it's place. It was tested in another car and it works fine. Only issue left is trying to find the ECU harness. I never knew about the 1 piece and 2 piece design. So you guys are saying I have to find a 2000-2001 GSR ecu harness, nothing else?
Old May 1, 2010 | 07:05 PM
xero_xero's Avatar
yes, all you need is a 2000-01 ECU harness from a GSR integra or the Civic SI harness 99-2000(although it is still a one piece design). SI harness and sohc harnesses are a 1 piece design (cars that come stock with the D16y8 or B16 96-2000). the LS integra ecu harness (96-2001) will not be wired for vtec even though the harness will plug and play.
Old May 1, 2010 | 07:11 PM
98civdx's Avatar
Master Detailer
^^ have any proff? I am not the only one that says you cant use integra harness in 96-00.
Not peice of information i cant find supports what you said, 96-00 civics use 1 peice harness.
Old May 1, 2010 | 07:15 PM
Weifast's Avatar
wait, so now ppl are saying a obd2b 99-00 SI harness will work with the 2000 GSR? I'm massively confused. If the 99-00 si harness will work, thats good too because at least I found one on ebay, but so far no luck finding a 2000-2001 harness though. I appreciate all the help, but whats the conclusive answer, does anyone know?
Old May 1, 2010 | 07:24 PM
xero_xero's Avatar
post edited above....
Old May 1, 2010 | 07:27 PM
98civdx's Avatar
Master Detailer
Op, the civic harness will work, hell you could use a dx harness if you felt the need lol as long as you add the proper things its missing.
Old May 1, 2010 | 07:30 PM
CivicSpoon's Avatar
Don't listen to xero xero. Use the Civic harness you have now, you don't need any other harness. Just add the extra wire(s) that you'll need.
xero xero - What you're talking about only works with '92-'95 Civic and Integras. If he tried to do what you're suggesting, he'd also have to replace the entire under dash harness as well. The harness he has now ('99 or '00 Civic harness) will allow the new '00 P72 ECU to plug right in.
Old May 1, 2010 | 07:32 PM
98civdx's Avatar
Master Detailer
also, i think theres differnces in the obd2a dizzy plugs and 2b, so you will would be better off useing your current harness.
Old May 1, 2010 | 07:37 PM
xero_xero's Avatar
Wrong, the ecu wiring harness is separate from the dash wiring harness. there is a standard plug that connects to all 88 to 2000 civic dashes and 90 - 2001 integra dashes to the ecu harness. find the ecu wiring harness for the GSR. you will need it for getting the engine BRD and maintaining the ecu you have. Your only other option is to utilize an odb2a ecu harness and ecu.
Old May 1, 2010 | 07:45 PM
98civdx's Avatar
Master Detailer
^ just stop now, your making your self look stupid.
op keep the harness you have and plug it right in.
The car is obd2b, not a. I dont know how much clearer i can make it.
The civic harness will work just fine and he CAN plug in the integra ecu to it.
Old May 1, 2010 | 07:58 PM
xero_xero's Avatar
Dur sped, the SI harness he has now is for a b16 which in turn is the same as the GSR. no adding or lengthening wires
there are guys on here telling him to add "extra wires for what he will need"
and then you (98civdx) tell him he could use a dx harness. your just setting him up for a head ache (a good bit of legntening wires and differences between d and b series).
you can use your current wire harness, but for ease of maintenance and installation I TOLD YOU MY BEST ADVICE for the easiest way for YOU. the 2 piece design allows you to install and remove the engine with ease.
Old May 1, 2010 | 08:02 PM
Weifast's Avatar
Hey guys, the motor I currently have is a 1999 JDM b16 sir2, I'm not sure if that is obd2a or obd2b, since the USDM b16a2 is OBD2b. I have to wait until monday to make sure. The motor came with the car and I haven;t had a chance to check to see what ECU he is running and what type of harness he ended up using. I really do appreciate all the help though, I'll get back to you guys and let you know whats up, I'm sure I'm going to run into some road blocks haha.
98civdx's Avatar
Master Detailer
first off, to use the secondary iabs he will need to add wires dip ****!
I was making a point, HE COULD if he felt the need, sure it will suck, adding lengthing what ever. I will all work!, b series or d!
Old May 1, 2010 | 08:04 PM
Weifast's Avatar
FYI to zero zero, I can't use any other ECU or any other combo. This is going up to CA state bar. ECU has to be the p72 obd2b 2000 GSR ECU, the one corresponding to the motor. No other ecu can be used and a jumper harness DEFINITELY CANNOT be used to covert back to obd2a if that is what you are suggesting, it won't pass state bar that way.
Old May 2, 2010 | 12:40 AM
kensei's Avatar
i think your best bet would be to find a 2000~2001 gsr engine harness and splice/swap over whatever connectors you need from the integra harness to civic harness (2ndary buterrflies, vtec, oil pressure, couple other ones i forgot). at least thats what i did for my 98 gsr swap on 98 hatch for BAR. since you bought the car with a swap, im assuming you dont know what/how the previous owner modded the civic harness to fit the jdm b16a. personally i would buy a unmodded 2000 civic dx/lx/ex harness along with the unmodded gsr harness and combining them together for a safer bet. doing it this way insures that you wont have headaches later on when your car suddenly doesnt want to start because of a bad connection/burnt wire/unpinned connector/etc.
heres a recommendation on where to get the harnesses besides egay:
1. go to maps.google.com
2. search for honda parts sacramento, ca (home of the largest wrecking yards in the states)
3. list of wrecking yards going to pop up, i would first try calling HAP (honda recycling), then some smaller yards and see if they are willing to ship.
i usually get all my parts from the wrecking yards in sacramento.
if you're going to the bar station could u help me ask one of the refs what's up with the new "no jdm motor swap" law. there are couple of dilemmas i heard.
1. being that only integras could swap over the jdm b18c (typeR) since it was originally equipped with a b18c5
2. or could previously bar'd members with b18c1/b18b can replace their engines with a jdm b18c
basically i want to know if i bar'd a gsr can i swap over a jdm b18c as a replacement. you probably would want to know too
Old May 2, 2010 | 01:07 AM
kensei's Avatar
after a little more digging through your posts and since no one gave you any tips for bar day:
1. no aftermarket anything....intake, header, cat, and intake manifold were replaced after i got my bar sticker on passenger side door. i rather not fail, schedule another appointment, wait, and come back because of a stupid intake.
in your case to answer the cat question, this is what i did. i welded two different pipes in between the header to exhuast. one pipe is really short so i can bolt on a cat to pass smog when i need to and one pipe is pretty long and straight for whenever my car does not need a smog. i needa find a headshield to weld to that pipe so i looks like i have a cat.
2. i think the monitor crap on couple other bar posts are referring to the monitors on the ecu that brings up the CEL. i think there are 2 monitors one at 30miles and another at 60 miles. so that means the CEL wont come on even though it detects a problem until after 30miles and 60miles. so make sure u drive the car at least 30~60miles before going to the bar station.
3. no CELs
4. arrive early, most of these bar stations are at some school in my case, some ****ed up adult school. i spent 15 minutes trying to find which part of the school was for the bar station. after finding out where it was, i had to go back outside and repark my car into a designated parking spot for cars being bar'd.
5. i remember thinking about paper work. i did not bring any because the motor's vin number referred to a gsr that my cousin owned. so i know in the dmv database it did not have the words stolen on it. iono where u got your motor but i would bring some kind of paperwork/bill of sale stating that motor is yours. cause worst case scenario they could call the cops and your car would be impounded for being stolen property.
6. it was a pretty easy thing to do. there wasnt anything much for them to check. one of the guys showed me a packet of about 10+ pages of printouts that had diagrams of varies things they checked. mainly it was items that involved the emissions (evap, charcoal canister, purge solenoid, ecu vin number, etc).
i think thats about it. im sure u kno its only a visual inspection, no more sniffer test. remember to help me ask about jdm motor swaps. and good luck hope to see you at some norcal track events.
Old May 2, 2010 | 01:51 AM
Weifast's Avatar
MAN KENSEI!! You are the man! THanks for all the help man! I'll repost and let you know about the situation. Since I haven't had a chance to go back to my buddies shop yet and I'm still waiting for the ECU at hand, I can't really say until we actually drop the GSR in. I just removed the b16a SIR2 today. We'll see how everything goes and we can take it from there, and of course I'll help you out, it'll probably take less than a few minutes to ask anyway. Thanks again man! Hopefully you'l be back to help some more after I figure out if something is really wrong or the harness already in my car is OBD2b or the previous owner modified it.
Old May 2, 2010 | 05:46 AM
canadaek's Avatar
=98civdx;42349874]first off, to use the secondary iabs he will need to add wires dip ****!
2nd ^
Old May 2, 2010 | 11:55 AM
98civdx's Avatar
Master Detailer
Only thing you should have to add is iabs, everything else should plug right in, 2b is 2b, civic or integra.
