clutch slipping?
Old May 1, 2010 | 11:24 AM
crazihobo's Avatar
Default clutch slipping?
wells im not sure if the clutch is going out.. but i bought the car this way so yeah. so when im smashing on the car my rpm is going up finee but its not picking up speeed fast enough. it goes into gear fine. my tranny feels really soft going into gears. and i do feeel like the clutch is not grabbing hard enough to pick up speeed. is it my clutch or something else?
Old May 1, 2010 | 11:26 AM
D16SiHatch's Avatar
Default Re: clutch slipping?
if you notice the rpms getting higher and you can tell the connection from the engine to the tranny is slipping then yes it's definitely your clutch.
Old May 1, 2010 | 02:25 PM
crazihobo's Avatar
yah the higher the rpm the more you can tell the connection from the tranny and engine.
Old May 1, 2010 | 02:29 PM
Crash6066's Avatar
well easy way to tell is get into third gear around 2k adn the mash the gas. if the rpms go up and ur not goin any where its definitally the clutch
Old May 1, 2010 | 09:31 PM
crazihobo's Avatar
hm okay im started to think its my flywheel.
Old May 1, 2010 | 09:43 PM
Crash6066's Avatar
well what about it? if you think the flywheel is bad then thats a great chance that its also the whole clutch unit too
Old May 2, 2010 | 09:09 AM
crazihobo's Avatar
wells thats cause i bought the guy 6 months ago they told me it was a new clutch..but since it was a homemade job im starting to feel like he did not redo the flywheel.
Old May 2, 2010 | 11:04 AM
Crash6066's Avatar
thats a great possibility. and leaks around the tranny?
Old May 2, 2010 | 02:16 PM
crazihobo's Avatar
hm of coruse theres leaks around the tranny thats normal isnt it? for all my hondas there was always leaks. so i didnt bother to care.
Old May 2, 2010 | 07:05 PM
Crash6066's Avatar
a good running honda doesnt leak anywhere. if there is a leak around there it is most likely the dizzy o-ring. or you have a valve cover leak or worst case head gasket is blown but not bad.
Old May 2, 2010 | 07:41 PM
majrneo's Avatar
i always thought and did it this was, pull E-Brake so car wont roll, put it in 4th gear and slowly lift your foot off the clutch and give it gas, if the car does not die, you need a new clutch, if it starts die regardless of how much gas you give it then your clutch is good
Old May 2, 2010 | 08:25 PM
Crash6066's Avatar
yeah but in doing that you can were down you clutch that way too. but i guess that would work to. props for idea lol
Old May 2, 2010 | 08:54 PM
crazihobo's Avatar
ok ill try it sometime this week.
Old May 4, 2010 | 10:03 PM
crazihobo's Avatar
ok i did that 4th gear ebrake thing just a little of gas tho not too much about 3krpm just enough for take off it did stall. so that means my clutch is good would that have to do anything with my flywheel or pressure plate? cause i really feeel like my clutch is spinning in high rpm. but im not sure.
Old May 4, 2010 | 10:09 PM
t3h jam's Avatar
Ok. Listen, this is easy. Drive the car, get to around 30 mph, put it in 5th and mash the gas and hold it to the floor. If the car keeps moving, but very slowly (obv) your clutch is fine. If it slips, and revs like it's in neutral then your clutch is slipping
Old May 4, 2010 | 11:08 PM
honda_luvr_2000's Avatar
Originally Posted by crazihobo
...so that means my clutch is good would that have to do anything with my flywheel or pressure plate? cause i really feeel like my clutch is spinning in high rpm...
If the flywheel or pressure plate are "slipping", then the clutch is slipping. If the engine seems to be "accelerating faster" than the car, then the clutch is slipping.
Another testosterone clutch test is try to do a burnout in 2nd gear at a stop on a slick surface (painted/sealed payment) dump the clutch holding the RPM's at 3000. If it does spin the tires- clutch likely ok. If the engine keeps going but no tire spin, really slipping clutch. If the engine bogs down then the car begins to creep or go but no spinning tires, clutch.
Now I don't recommend doing this frequently or for very long, just to give the clutch a real quick hard test. When the clutch is good this will put a large shock load on the drivetrain, but since you're fairly certain the clutch is slipping then the slipping clutch is what will take the shock load and not the drivetrain.
t3h jam's test is a good one too, and puts less stress on the drivetrain regaurdless of the clutch's condition.
Whichever test you do, be smart about it. Don't do it in a garage, busy bank parking lot (they are often painted/sealed), busy road, etc.
Old May 5, 2010 | 12:22 AM
crazihobo's Avatar
okay thanks guys for sure the engine is acclerating faster than my car tho.. so yeah
Old May 5, 2010 | 04:08 PM
crazihobo's Avatar
hey can it be possible that its my axles?
mfisher1987
Transmission & Drivetrain
Feb 8, 2015 05:58 PM
roachsboosted16
Jan 9, 2010 04:30 PM
SiMateoAko
Sep 7, 2006 12:42 PM
rriicckk787
May 10, 2005 05:13 PM
FLCivic
15
May 31, 2004 09:22 AM
