Car not starting
Old May 1, 2010 | 11:18 AM
Egpower88's Avatar
Default Car not starting
Alright here's the problem my car is a 94 civic hatch.. I'm not getting any gas pressure, the car turns over but doesn't start.. Swap a main relay with a buddy of my n that's not the problem.. My cel stay on when I turn the key to the on position.. Any clue??? I was thinking maybe a fuel pump problem.. Help please
Old May 1, 2010 | 11:25 AM
Former User's Avatar
Default Re: Car not starting
Check whether hood fuse 31 or dash fuse 24 or 18 is blown. Also check whether the G101 ground attached to the thermostat housing is loose or corroded.
Old May 1, 2010 | 11:33 AM
Egpower88's Avatar
Ok my car don't have any of the fuse number u listed.. N my ground wire looks fine on the thermostat
Old May 1, 2010 | 11:42 AM
Remove the ground, sand it to a shiny metallic sheen, tighten up.
Old May 2, 2010 | 04:45 PM
Egpower88's Avatar
Ok thanks for all that, but all my fuse r good.. And I sand down that ground wire n still no gas pressure.. I'm just gonna replace the fuel pump n c if that works.. When I turn on the key I don't hear the pump priming or anything.. Isn't there like a click kinda noise when u turn the key to the on position then the cel will shut off?? That must b the main relay??
Old May 2, 2010 | 05:00 PM
SpeedoKing's Avatar
yeah it sounds like the fuel pump if your fuses are all good...same thing just happened to my friend.
Egpower88's Avatar
Ok what cause no gas pressure, before I go n buy a fuel pump tommorow?? Anything esle I can check to c y I'm not getting gas pressure?
Old May 2, 2010 | 05:02 PM
Egpower88's Avatar
Cool man.. I'll try that tommorow n let u guys know if it works..
Old May 2, 2010 | 05:06 PM
HondaPartsHero's Avatar
Technical Hero
if your CEL stays on you should probably pull the codes first and see what its showing
Dc295kid
Jan 1, 2011 04:47 PM
kirkland08
Jun 17, 2010 09:12 PM
sireg6
Jul 29, 2006 09:40 PM
ZaxEG
Aug 30, 2004 05:25 PM
