Tire Question
Old May 1, 2010 | 10:23 AM
Justimo's Avatar
Default Tire Question
Hey, I searched this but I couldn't find a thread that talked about it...
What kind and size of tire do you guys put on your 16X6.5 rim setup? More specifically JDM 16" ITR rims?
215/45/16? 205/45/16? What brands? Potenza RE760??
Old May 1, 2010 | 03:50 PM
CWTegRNo.160's Avatar
Default Re: Tire Question
Bridgestone Re-11's are a favorite for itr owners. Dunlop star specs are another favorite. I wont comment on tires size cause I have 205-50-16 on my c10s.
Old May 6, 2010 | 03:08 PM
nsxtasy's Avatar
H-T Order of Merit
The best 16" tire sizes for an ITR are 205/45-16 and 215/45-16. However, 215/45-16 is too wide for a 16x6.5 rim, so you'll need to get 205/45-16.
As for what kind of tire, it depends on what you need.
If you need to use the tires in snow and bitter cold in the winter as well as warmer weather the rest of the year, you'll need all-season tires; I recommend the Kumho Ecsta ASX.
If you don't need to use the tires in snow or bitter cold (because the weather doesn't get cold where you are, or you have another set of tires or another vehicle to use in that weather), then you can take advantage of the higher performance of summer tires. If you want the best performing summer tires and you don't care that they won't last as long or may cost more, I recommend the Bridgestone Potenza RE-11 or Toyo Proxes R1R. If you will use summer tires for daily driving and you care about how much they cost and how long they will last, I recommend the Yokohama S.drive. (The Bridgestone Potenza RE760 Sport is also very good, but significantly more expensive.)
Old May 6, 2010 | 04:40 PM
IanBlake's Avatar
falken azenis 215/45R16 that is what i have on my JDM 16, and 215/45R16 that's the original size
Old May 7, 2010 | 09:32 AM
nsxtasy's Avatar
H-T Order of Merit
The Azenis in 215/45-16 is not approved by the manufacturer for mounting on 16x6.5 rims.
Is it possible the rims are not 16x6.5, but are instead 16x7?
Old May 7, 2010 | 09:40 AM
Todd00's Avatar
I said I don't want a title!
Yeah, since when are the JDM ITR wheels 16x6.5"? Pretty sure they are 16x7, +50.
Old May 7, 2010 | 09:58 AM
nsxtasy's Avatar
H-T Order of Merit
If they are 16x7, that opens up choices in 215/45-16, including the Kumho Ecsta XS as well as the Azenis RT-615K. These, as well as the RE-11 and R1R, are "extreme performance summer tires", the stickiest street tires you can buy.
The Bridgestone Potenza RE760 Sport which you originally mentioned isn't as sticky as these (that's why Bridgestone makes the RE-11), but it lasts longer and costs less. Other good choices in longer-lasting summer tires include the Yokohama S.drive and Fuzion ZRi, both of which are usually less money than the RE760.
All of these tires are summer tires and should not be used on snow or in frigid cold.
decko
Nov 9, 2010 06:17 AM
Si87
Honda Civic (2006 - 2015)
26
Oct 19, 2009 04:34 PM
No-Gi
Oct 2, 2006 12:10 PM
SpoonSpecR
May 19, 2003 07:44 AM
TurBoXBirD16
Feb 6, 2002 06:17 AM
