Who has AC with a B series swap?
Just wondering how the install is? Do you have to do anything custom, such as custom AC lines or. anything that makes the job tough? I am planning on using the Hasport ac adapter bracket and I have Hasport mounts. Thanks for any help.
You need the custom bracket, sanden model compressor and lines, new a/c drier, I suggest getting new expansion valve.
The a/c lines are stock lines from a 88-91 civic or crx with a sanden compressor. Mitsuba compressors and lines are different.
After those are replaced/installed get the system evacuated so there is no debris in it. Then fill with r134a or have a shop fill yor system with r12
