for sale: programmable revlimiter for analog msd boxes. MSD 75611
Old Apr 30, 2010 | 05:22 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default for sale: programmable revlimiter for analog msd boxes. MSD 75611
this is a programmable rev limiter. works with all analog boxes. this box works well but will not work with my current setup.
msd 75611 programmable rev limiter box. works with all analog boxes.
http://www.msdignition.com/Products/RPM/Timing_Controls/RPM_Controls/75611_-_Programmable_Launch_Rev_Control.aspx
Too much power can actually be a hindrance when it comes to hooking up a small tire or the prop of a drag boat. For anyone with this “problem” the Programmable Launch Limiter is the answer. This microprocessor controlled Limiter plugs in place of an rpm module in an MSD Ignition or Soft Touch unit. You can then go in and program a launch-based rpm ramp based on rpm and time. This is set in 100 rpm steps down to 0.001-second increments by using MSD’s Pro-Data+ software on a PC or with the optional Hand Held Monitor, PN 7550. There is also an adjustment that sets a delay time before the rpm limit activates. This way, when you launch the rpm limit will kick in exactly when you want it to and ramp up to your race rpm for the rest of the run. This Limiter can be used with most of MSD’s Ignitions or Rev Controls (except the 7AL-3 and 10-Plus) that use the plug-in rpm modules. The Pro-Data+ software is supplied.
the box is 2 years old, plenty of length on the wires. well taken care of. i think we are getting a handle on the car without it.
testing waters, but if interested,
200 shipped.
Old Apr 30, 2010 | 06:21 PM
Mr. Badwrench
Default Re: for sale: programmable revlimiter for analog msd boxes. MSD 75611
you can apply the revlimiter over time with this box. the way we had mine setup was to hold the engine back starting at the launch rpm, and only let the engine rev as fast as the timer would let it. it increased the revlimiter from 8000-10k over 1.4 or so seconds. effectively it acts as a traction control. it is very easy to use, the manual and program can be downloaded on msd site if you want to look into it.
Old May 1, 2010 | 04:12 AM
Mr. Badwrench
bump please!
Old May 1, 2010 | 04:09 PM
Mr. Badwrench
Old May 2, 2010 | 10:44 AM
Mr. Badwrench
90tegboosted
Engine Management and Tuning
May 24, 2013 04:31 PM
CIVICD16A9
Jul 4, 2005 08:26 AM
torr
Aug 4, 2004 08:08 AM
Specialblend27
Feb 17, 2003 09:46 AM
