gsr, what is this, and can it be removed?
Old Apr 30, 2010 | 02:11 PM
x_doug-x's Avatar
Default gsr, what is this, and can it be removed?
can this be removed
Old Apr 30, 2010 | 02:58 PM
crazycornuts's Avatar
Default Re: gsr, what is this, and can it be removed?
First Q
Why do you want to remove it?
Old Apr 30, 2010 | 03:24 PM
x_doug-x's Avatar
i'm too lazy to modify a bracket for it, i have a edebrock intake manifold and theres no mounts for it.
Old Apr 30, 2010 | 04:16 PM
B18CivicEJ8's Avatar
In your case, yes, it can be removed. It's the intake air bypass valve. It's to engage the second stage in the GSR's dual stage manifold. Since you're switching to a single stage manifold, it's not needed.
Old Apr 30, 2010 | 07:40 PM
x_doug-x's Avatar
thank you for your help..
Old Apr 30, 2010 | 08:33 PM
DDTECH's Avatar
you can remove it..its not important.
Old Apr 30, 2010 | 11:18 PM
raidacaipo's Avatar
It is if you plan on using that stock gsr manifold with the iab function. Its all important if you plan on selling that whole intake manifold because it would be worth more.
Old Apr 30, 2010 | 11:21 PM
DDTECH's Avatar
That doesn't control the iabs.. just a fyi, at least not when i had a gsr manifold.. vac hose was routing another way, the only thing that controls the iabs is the flat round thing,
http://www.ff-squad.com/tech/howto/s.../manifolds.gif
picture on the right top side of the manifold..when the gif comes up for "GSR"
http://www.ff-squad.com/tech/im/p72.im_1.jpg, This shows what your saying, however, my lines were routed another way, none the less..
Old May 1, 2010 | 12:13 AM
raidacaipo's Avatar
I never said it controlled the iab.. the p72 ecu does. I said you need it to function with the iab. It has a sensor for it which is the iab connected to the box. Are you saying that you never need that when you had your gsr for the iab's to work? well guess what? your iabs never worked then. Your iab must have been open this whole time if your vacuum hoses weren't correctly plugged in. That box is like a vacuum. You can actually unplug one of the hoses coming from that box and it will suck your fingers. You can also she how it sucks open the throttle for the iabs on the purge solenoid when you turn the ignition to the on position. You can actually see the throttle for the iabs slowly move therefore, shutting 4 valves.
eg93LS
Jun 10, 2009 09:12 PM
()()DC2
Nov 5, 2006 08:04 PM
tomlinson619
Apr 14, 2006 05:25 AM
HondaTeg95
Sep 28, 2005 08:04 PM
ZXVIIR
Jul 8, 2002 09:55 AM
