Can't figure out why this car won't stay running
I have no clue what's wrong
with this car when I turn the key it will start but when I let go it just dies i don't kno if it's the injectors or what. I recently replaced the plugs and wires that's about it with ignition can someone help me out please
If I give it gas still just dies out
and I look for the one on the ignition switch and check it
this frustrates me cause it could be so many things
try this if it works. Just wire a power wire to the fuel pump sensor. Take off the sensor from the fuel pump and wire a power wire to the yellow wire. If you did it properly you'll hear the fuel pump on. My friend had this problem. He did what i told him to do. If this solve your problem, you might need to wire the power wire to a switch.
This happened to me when I first bought my EG, and it was the fuel pump, but then again the car was sitting for over a year
93 civic ex d16z6, but i figured it out its the ignition switch i have to swap it out, the reason i said this is cause i took it off cleaned off the terminals and it worked again but its doing it again now is i figure thats gotta be it
SHG_Wacky
Feb 21, 2007 08:25 PM
B16CRXT
18
Dec 12, 2004 07:45 PM
B16CRXT
Dec 10, 2004 03:40 PM
VTECAcuraGSR
Apr 10, 2002 12:04 PM
