DOHC ZC??
wassup guys as you can see im a noob here..
wanted to do my first swap and wanted to go with the dully zc but there's like 3..http://www.jdmenginedepot.com/search_results.php i wanted to with the first one but it say 92-95..i still wanted to use my cable trans for it..and do i have to do the mpfi? cant i just get a si harness make life easier? help me out guys thanks
youre choosing the newest one its OBD1 came in EG bodies in japan but can also be swapped in EFs you will needa convert to mpfi and no i dont reccomend getting another harness you have to work with your stock harness and modify it...
and yes any D series L3 cable tranny will work
heres a site with alot of helpful info on this swap
thezcr.com
thezcr.com
yeah same mounts D series will bolt right on
but if i was you i'd rather go with this one
http://www.jdmenginedepot.com/jdm_en...egra/Civic/CRX
lol the question is why the other one if youre not planning on swapping it on an eg?
why go thru the hassle of obd1 and extra wiring and have the 3rd gen ZC when everybody else has the 2nd gen ZC that was made to fit and work on EFs plug and play or so to say...
not like it has more power vtec or less miles...
yeah..this is what i know for the swap..mpfi first..i can use the same tranny..use the same mounts..(money saver
) only new things i have to get is a 88-89 teggy ecu and teggy axles correct?
Redemption
Sep 25, 2009 09:48 AM
The Destroyer
11
Dec 30, 2005 02:22 PM
