93 EG WHAT FRONT CAMBER KIT TO RUN ?
Old Apr 29, 2010 | 11:07 AM
hardspike's Avatar
Default 93 EG WHAT FRONT CAMBER KIT TO RUN ?
RUNNING FUNCTION N FORM TYPE 1'S,WITH 18'S.WHAT CAMBER KIT IS THE BEST TO RUN ON THE FRONT?
THE ADJUSTABLE CONTROL ARM WITH BALL JOINT
OR JUST THE ADJUSTABLE BALL JOINT
OR THE UPPER PIVOT ARM BOLTS?
Old Apr 29, 2010 | 11:11 AM
BoldFart16's Avatar
Default Re: 93 EG WHAT FRONT CAMBER KIT TO RUN ?
The best camber kit would be get smaller wheels.
Old Apr 29, 2010 | 11:19 AM
96hb's Avatar
The best camber kit to run is an alignment.
Old Apr 29, 2010 | 11:29 AM
hardspike's Avatar
DUMBA$$ ANSWERS
Old Apr 29, 2010 | 11:36 AM
96hb's Avatar
Why do you think you need a camber kit?
Here you go, read this.
https://honda-tech.com/forums/suspension-brakes-54/no-you-do-not-need-camber-kits-2614449/
Old Apr 29, 2010 | 12:48 PM
BoldFart16's Avatar
DUMBA$$ question from a DUMBA$$. You DO NOT need a camber kit, get smaller wheels, get an alignment. READ THE FAQ. A$$ hat.
Old Apr 29, 2010 | 01:04 PM
Vindicator9000's Avatar
318 Curves, 11 miles
I've been running -2* front, -2.5* rear for over 2 years with only a little camber wear. Personally, I'm thinking about dialing down my rear camber with a few washers to help turn-in, but it's definitely not killing my tires, and has an overall positive effect on cornering.
A little camber is a good thing. Figure out what your alignment numbers are and post them, then we'll tell you if you even need a camber kit.
Old Apr 29, 2010 | 01:23 PM
hardspike's Avatar
well my problem on that is,i'm still building the car and i like to have it installed before going for a wheel alignment.I'd like to drop it as much as i can on the 18's..As i also painted all of my suspenion painted with endura paint...so the less times i have to take it apart to avoid messing up the paint job...........
jmai86
Suspension & Brakes
Jul 27, 2009 04:58 PM
shackler
Dec 31, 2006 09:46 AM
Sandor
Nov 17, 2003 09:01 AM
clutch33
Oct 29, 2003 04:54 PM
importimage
Oct 15, 2003 01:43 AM
