help with putting a b18a in a 90 hatch
Old Sep 11, 2002 | 08:56 AM
elpermgrande's Avatar
Default help with putting a b18a in a 90 hatch
I am planning on putting a B18a from my friends wrecked 90 integra into my 1990 si hatch and was wondering what all I needed to change out?I figure I can use the stock radiator, I already have the engine mount kit, do I need to change the wiring harness or will the si plug in with a little modification?Please let me know.
Old Sep 11, 2002 | 09:12 AM
curiousgpnoy's Avatar
Default Re: help with putting a b18a in a 90 hatch (elpermgrande)
everything should plug in...as long as you are using all 90-91 integ parts, such as; injectors, distributor, and ecu.
Old Sep 11, 2002 | 09:20 AM
Default Re: help with putting a b18a in a 90 hatch (curiousgpnoy)
yes everytyhing is from a 90 integ so I am gonna give it a shot.thanks fro the reply.any body elses comments welcome also
Old Sep 11, 2002 | 09:31 AM
EF_LSVtec's Avatar
besides the injectors, ecu, distributor...you will need the rear engine bracket of the 90 teg (for your rear mounts) and also the intermediate shaft and axles. Make sure to remove the dust cap from the knuckles and spacer from the axles for better fit. Upper and lower radiator hose, cut and reweld shift linkage to fit or get one from hasport.com
Old Sep 11, 2002 | 07:44 PM
Default Re: help with putting a b18a in a 90 hatch (EF_LSVtec)
ttt
helpmeplease
Mar 9, 2007 07:42 AM
Vsm Hatch
Jul 8, 2004 05:36 AM
SiB16A
Aug 14, 2003 11:22 PM
slow hatch
Nov 13, 2002 06:58 PM
