Classic Hondas All Pre-1988 Hondas.
ECU and engine/head mounting questions
Old Apr 29, 2010 | 12:24 AM
Castaway2000's Avatar
Default ECU and engine/head mounting questions
i have a 1987 CRX SI OBD-0 i am pretty sure, will a p28 ECU connect directly with this cars stock connectors?
also will a D16z6 (with VTEC) head bolt on to the stock engine(D15A3) if so is there a good way to connect the VTEC correctly and easily?
i have intentions to keep this car stock till the 1st engine goes, so mainly i am just curious more or less...
Old Apr 29, 2010 | 01:17 AM
E-AT_me's Avatar
Default Re: ECU and engine/head mounting questions
no and no..
Old Apr 29, 2010 | 07:22 AM
cbstd's Avatar
To amplify:
Hondas from the 1987 and earlier model years are VERY differrenrt from 1988 and newer Hondas. Come on over to www.redpepperracing.com for specific info about your car, the wiki on that site should get you up to speed on your '87.
Scott
Old Apr 30, 2010 | 08:07 AM
Originally Posted by cbstd
To amplify:
Scott
i have been over at RPR before now i just need to set up an account thanks for this info
Old Apr 30, 2010 | 08:08 AM
Originally Posted by E-AT_me
no and no..
thanks thats what i was assuming as well
Old May 1, 2010 | 12:20 AM
Gabe87CRX's Avatar
Yea... there is pretty much no aftermarket support for the 87 CRX.... and for what ever is out there, its very expensive...
Old May 1, 2010 | 10:18 AM
helldriver88's Avatar
hasport now makes a mount kit to drop a 1988+ D/B series engine in your EA, EW, and DA3. thats ONLY if you were dead serious about this idea, because Hasport kits are expensive as fawk. also, you can get a OBD0-OBD1 ECU jumper harness just about any tuning shop or just order one online. but once again, the swap is expensive and is usually only worth it if you've got a serious powerplant such as a B16A or etc.
BTW, if you didnt already know, the 1986-89 Integra's D16A1 will drop right it. they only put out 113-115hp from the factory but they are next to free since nobody wants them. i've gotten all of my D16A1 swaps for free.
Old May 3, 2010 | 08:34 AM
this is good to know! my plans for this car is to keep it stick till the engine goes then supe it up with a bigger engine and make it a playtoy this is great info!
92lxsleeper
Northeast (Sales)
Jun 20, 2009 10:20 PM
slayerfromhell212
22
Dec 28, 2006 06:39 PM
ABK
Mar 6, 2004 03:57 PM
elmerfudd
Jul 28, 2002 10:25 AM
FlipboiGSR
Sep 12, 2001 11:31 AM
