FS- B series turbo kit or willing to partout
AFI Stage 3 B Series Bottom Mount Turbo Kit
The kit is missing the intercooler, but has the rest of parts.
AFI Bottom Mount Manifold with T3 Turbo flange and 44mm wastegate flange
Garrett T3/67 Turbo with S cover compressor housing, .63 and .82ar exhaust housing, Stage 5 High Output wheel, 4 bolt turbine discharge, Supports 725whp
AFI 3 inch Down pipe 4 bolt turbine side with v-banded flange on catalytic converter side
Tial 44mm Silver wastegate with dumptube
AFI EG-EK intercooler piping kit with tial 50mm bov flange
Tial silver 50mm blow off valve
PWR silicone couplers and T-Bolt Colamps
Stainless Steel 3an oil feed line
Oil Return push to lock line with 10an fittings
The kit was installed on car for a week and has no miles on turbo. Started car to make sure timing on motor was correct and also to check that new motor was not knocking or had leaks anywhere. That is not a misprint in the ad for exhaust housing on turbo, it comes with an additional .63ar back hosing never installed. I sold the intercooler to a friend so kit does not come with the back door style intercooler as in a complete kit, asking $2,500 obo. I'm located in CT, also willing to part out
GEN2 LS
Aug 25, 2013 05:23 AM
audiko4
Apr 30, 2010 09:44 AM
