Starter Gone Bad
Old Apr 28, 2010 | 05:55 PM
azandford's Avatar
Default Starter Gone Bad
I hopped back in my car after being in the house for 2 mins and ohing hapened when tried to start the car. Just a click noise. didnt turn over or anything else>
Heres what ive done...
charged battery
checked batter for juice with volt reader
Checked the juice going to the starter (good)
wont even turn over which leads me to believe its the started although it did not give me any problems before this happened
Old Apr 28, 2010 | 06:02 PM
shogee's Avatar
Default Re: Starter Gone Bad
sounds like the starter, you could check the starter solenoid there should be power on both sides of the solenoid when you turn the key to crank
Old Apr 28, 2010 | 06:28 PM
redeg666's Avatar
lighty wack the starter, if it starts its a starter, also a part store will check the starter if you take it out, autozone, advanced auto
Old Apr 29, 2010 | 05:59 AM
azandford's Avatar
oh i will get ot whacking having a hard time taking it out though i broke off two 14mm bolts already on it where exactly is the starter solenoid located?
Old Apr 29, 2010 | 06:03 AM
95coupeb's Avatar
CHECK GROUND ON TRANNY. mine was doing the same thing. and then i went and right before i pulled the stater to bring to autozone to get tested. pulled the groudn sanded down teh eyelet alittle. and the arear where it bolts to teh tranny. and waaaala it worked.
IIXtremeHansen
24
Jun 11, 2007 10:28 AM
skn181
Mar 23, 2007 06:02 PM
WTB AUTO EK
May 12, 2005 06:46 AM
00fbp
Jul 15, 2003 07:30 PM
Sukebei Oni
Mar 16, 2003 01:21 AM
