engine sputtering?? help
Old Apr 28, 2010 | 04:39 PM
!!miguel!!'s Avatar
Default engine sputtering?? help
usually during 1st and 2nd when im crusing about 2k then im floor it..it will go till about 28k then the engine will start sputtering?? then the sputtering will stop around 32k? sometimes it does this during higer rpms
any one know what might be worng?
when i serched some guy had a similer prob but he changes out the spark plugs and it went away another change the fuel filter cause hes was clogged and then it went away...
well i already changed the fuel filter and it wasnt that!
im about to buy brand new spark plugs and if its not that
what do you guys think it might be?
Old Apr 28, 2010 | 04:55 PM
!!miguel!!'s Avatar
Default Re: engine sputtering?? help
also another problem i forgot to mention just dont want to make another thread
when im on the freeway the engine light goes on...and its only on the freeway..and it usuallys goes on when the car gets a lil bouncy witt the messed up freeways around here and cause the car is lowered...
any tips or info on this?
and the car does not over heat or anything if that matters
Old Apr 28, 2010 | 05:31 PM
BiG ChOr!Zo's Avatar
sounds like a dpfi throttle body and tps problem...look up the ecu for codes and go from there...!!!
Old Apr 28, 2010 | 09:23 PM
!!miguel!!'s Avatar
how would i look for the code?
sorry im kinda a noob...
but thanks for helping out
Old Apr 29, 2010 | 12:47 PM
pull back your passenger side carpet,turn the key to where all the cluster lights come on and count the flashing red lights in the ecu...!!!
triton318
May 22, 2011 04:51 AM
JDMgunmetalCRX
Feb 22, 2009 06:32 AM
Project_Civic
Apr 3, 2005 05:07 PM
DemostheneZ
Jul 13, 2004 09:56 AM
Hapa88
Apr 23, 2003 10:45 AM
