stripped acorn nut
Old Apr 28, 2010 | 02:10 PM
untitled23's Avatar
Default stripped acorn nut
one of the acorn nuts on the valve cover is stripped.how am i suppose to get this off?
Old Apr 28, 2010 | 02:29 PM
vtaker's Avatar
Default Re: stripped acorn nut
You should be able to get it off with a vise grip positioned correctly.
Otherwise:Craftsman Bolt&Nut remover
Old Apr 28, 2010 | 02:31 PM
egsleepercivic's Avatar
i used a dremel when it happened to me, be prepared to replace the stud as well when you remove it, it may not be needed but would reccommend it
gl
Old Apr 28, 2010 | 03:25 PM
untitled23's Avatar
well i got it off with a drill and a screw driver.both stud and nut are stripped so ill buy another one tomorrow
Old Apr 28, 2010 | 03:30 PM
vtaker's Avatar
just FYI you'll probably have to order it from the dealer. could take a day or two.
Old Apr 28, 2010 | 04:58 PM
EHondaJDM's Avatar
Next time u should use a turbo socket, it has a sharp thread on the inside of the socket to grab a stripped nut or bolt, I don't know who exactly carrys them. I got mine from snap-on, and im pretty sure cornwell carrys them. Saves a lot of time and aggrivation, and in your case, a stud
Old Apr 28, 2010 | 05:01 PM
I think the problem the OP is having is that you can turn the nut it just doesn't come off not that the socket can't grab it
Old Apr 28, 2010 | 05:26 PM
civicsmoke's Avatar
next time you can try cutting a slot for a flat head screw driver.
Old Apr 28, 2010 | 06:59 PM
EHondaJDM's Avatar
he didn't even specify, title said "stripped acorn nut"
So if it was the threads of the nut than you should've just pryed up on the valve cover with a screwdriver a little to put pressure on it to come up
Old Apr 28, 2010 | 07:02 PM
redeg666's Avatar
u can take a socket that almost fits and hammer it on and take it off next time
Old Apr 28, 2010 | 07:15 PM
I know he didn't specify but I had the same problem before so I kinda knew what he was talking about
OP when you put the new stuff on just remember that those nuts only take 7ft/lbs of torque
Old Apr 28, 2010 | 08:22 PM
Schister66's Avatar
Man U FTW
I have this same issue and haven't really dealt with it yet. Its good to hear that it's less of a pain in the *** than i had imagined. Mine is stripped in the head and i'm sure i'll have to replace the whole metal sleeve-thingy...
Old Apr 28, 2010 | 09:44 PM
NACvicSi's Avatar
You can thank 99% of the people who over tighten them for that. You wouldn't believe the amount of people who over tighten them to the point of snapping the stud.
Old Apr 28, 2010 | 10:32 PM
inner four http://www.hondapartsunlimited.com/i...%20%28V-TEC%29
020 90014-PR3-000 BOLT A, HEAD COVER 1995 DEL SOL 5.57 3.90
outer four http://www.hondapartsunlimited.com/i...%20%28V-TEC%29
011 90012-PM7-000 BOLT B, HEAD COVER 1995 DEL SOL 4.27 2.99
I double checked, gsr and B16a are the same
I always try to keep an extra one of each around just in case
Old Apr 29, 2010 | 08:26 AM
Schister66's Avatar
Man U FTW
^^Thanks for the site...once i dig into this (after finals week) i'll be using this for sure
The nut itself is not the entire problem on my head...i have to remove the piece inside the head which the bolt threads into. Is that a huge ordeal??
Old Apr 29, 2010 | 09:56 AM
EHondaJDM's Avatar
The valve cover stud?? It has a nut head to take off with a deep socket
Old Apr 29, 2010 | 02:36 PM
its pretty simple just remove the valve cover then liked EhondaJDM said remove with a wrench and replace
Atauto
Honda CR-V & Element
May 27, 2015 04:19 AM
ryanangelo212
Oct 27, 2010 08:02 PM
Baodalazi
May 28, 2007 07:44 PM
SuperSi
Jan 29, 2006 06:54 PM
Beave0101
Aug 24, 2003 12:16 PM
