GSR-Skunk2 manifold install-coolant passage ?
MOTOR-JDM B18C GSR OBD2
i have all my vacumm lines figured out, just need help with the small coolant fitting next to the big fitting on the manifold. directions said get a t fitting and run to exsisting coolant line. i got a brass t fitting , just need input on where to run the lines to the proper way ? i am using the stock air intake & breather pipe. also what connects to the nipple above the throttle body? thanks in advance
totsie7944
Feb 4, 2008 03:01 PM
