Horn
Old Apr 28, 2010 | 12:00 PM
jmeyer99's Avatar
Default Horn
My horn stopped working. I have an aftermarket steering wheel, and I'm pretty sure I got the wiring connected right, and I have a good contact on the gold rotating disk behind the steering wheel hub. The horn fuse is good. I replaced the horn relay, and the relay clicks when I depressed the horn button. I pull the horn and wired directly to the battery, and the horn works fine. What else could be failing? Thank you.
Old Apr 28, 2010 | 02:13 PM
yamahaman63's Avatar
Default Re: Horn
You should test your relay again just because it clicks does not mean the relay is actually working properly. Test the relay at the pins. If the relay is still good check your horn button.
WaltL
Mar 20, 2015 11:47 AM
murphmatic
Jan 27, 2014 04:58 PM
zue1nia
10
Jul 6, 2013 11:06 AM
k7q
Oct 9, 2008 09:59 PM
oldbeefcake
13
Feb 24, 2004 08:34 PM
