valve seals bad, Rebuild or replace?
Old Apr 28, 2010 | 09:10 AM
Alexpbnj's Avatar
Default valve seals bad, Rebuild or replace?
my car smokes alot when i first start it for like 3 blocks then stops. i have a 98 civic hx i think it has the vtec-type e or whatever, im wondering if i should swap it out to a ls motor out of a 2000 i have the engine and ecu i dont know if i can still use my harness? but im wondering if its worth rebuilding at all?
thank you,
-Alex
Old Apr 28, 2010 | 09:29 AM
Ruben19's Avatar
Default Re: valve seals bad, Rebuild or replace?
go with the ls..
you need a B-series harness
Old Apr 28, 2010 | 09:53 AM
Alexpbnj's Avatar
thanks man
Old Apr 28, 2010 | 09:58 AM
Alexpbnj's Avatar
i had it priced the shop closest to my house wants over a thousand dollars to swap! thats wayyyy to much
Old Apr 28, 2010 | 03:28 PM
Alexpbnj's Avatar
ttt, should i just buy a new head and have the seals replaced?
Old Apr 28, 2010 | 04:04 PM
RICKSAUTOMOTIVE's Avatar
buying the head and replacing it would be cheaper.however, it may not be the head that is causing the smoke issue. could be the rings. but i'm just guessing on that. you might even fix it with a valve job and new head gasket
ITLNstallion818
Oct 12, 2008 05:08 PM
bruthaboost
Oct 21, 2005 05:51 PM
DOHCarp
May 9, 2003 01:14 PM
