to flush or ok? 17X7.5 38 mm SA70 Weds
Old Apr 28, 2010 | 08:55 AM
Garrett's Avatar
Default to flush or ok? 17X7.5 38 mm SA70 Weds
I look to buy Weds Sports SA70 wheels
In 17'' the width is 7.5'' width 43 mm offset
the car as about 2.25'' drop, no camber correction
do you think this will work on a ITR?
Old Apr 28, 2010 | 09:04 AM
get RIGHT's Avatar
Default Re: to flush or ok? 17X7.5 38 mm SA70 Weds
The words poke, flush or stretch should never be associated with an ITR. Ever. Ever.
Old Apr 28, 2010 | 09:06 AM
teg97's Avatar
agreed more like handling perfection
Old Apr 28, 2010 | 09:24 AM
Dr. DC2's Avatar
FAIL! Dont be one of these trend humping band wagon jumping pole smoking fanboi's! Put a size wheel and tire combo on your caR that will actually help performance. Otherwise, you dont deserve to own an ITR. go buy a civic and ********** to Phaze2
Old Apr 28, 2010 | 09:41 AM
PaulMc's Avatar
Painfully Stupid
17's are too big for an Integra Type-R, or any Integra in that matter.
Old Apr 28, 2010 | 09:57 AM
Todd00's Avatar
I said I don't want a title!
If you use the proper sized tire, they'll probably work. You may need to roll your rear fenders a bit and you may get some rubbing up front, but possibly not if you leave camber as-is.
This also depends upon springrates firm enough to support that 2.25" drop. You may find that you need to raise your car up slightly.
17" wheels give you no performance benefit unless there is a tire in a certain OD and width that a 15" or 16" wheel does not offer.
Old Apr 28, 2010 | 12:12 PM
Garrett's Avatar
this has never be a look, flush, poke or stretch issue, I hate it
the wheels are Sa-70 and they are only available in 17 for ITR
the only width available is 7.5''. so I want to know if I could use it
Old Apr 28, 2010 | 03:30 PM
get RIGHT's Avatar
Oh, in that case. Todd00 gave some excellent advice in a post above.
Can I ask why are you going with 17s versus any other size?
Old Apr 28, 2010 | 03:31 PM
Garrett's Avatar
SA70 aren't available in 5X114.3 in 16''
Old Apr 28, 2010 | 03:40 PM
get RIGHT's Avatar
I see. Aside from the size, the reason I ask is Weds are usually on the heavy side. That being said I dont know the weights of these off hand.
Old Apr 28, 2010 | 03:46 PM
Garrett's Avatar
16.7 lbs for 17''
Old Apr 29, 2010 | 08:36 AM
beat's Avatar
Should fit OK, rear fenders need to be rolled, fronts should be OK
I had LE37t's in 17x7.5 40offset with 215.45.17 tires and there was only minimal rubbing
Old Apr 29, 2010 | 09:17 AM
JjuuN R's Avatar
Says you? *jack off motion*
Pretty sure he was just looking for answers from someone with experience with the around the same size wheels he's looking at getting. Not half assed theories from the Type R **** Peanut Gallery
Old Apr 29, 2010 | 10:10 AM
Dr. DC2's Avatar
^^ROR!
Old Apr 29, 2010 | 03:49 PM
srt4mike's Avatar
Old Apr 29, 2010 | 05:07 PM
Dr. DC2's Avatar
srt4mike FTW
Old Apr 30, 2010 | 12:26 PM
RedTeg#3707's Avatar
@ garret ->
i think this should work
I drive some ATS competition wheels in 17x7,5 with an offset of 45mm.
the tires are 205/40 Toyos ( but they have a realistic width of 215)
My rear fenders are rolled (only the inner edge was bent over)
i dropped the car not as much as you want, but with the right chamber it should work.
official_del-sol
Feb 10, 2015 07:50 PM
dannythewonder
Honda S2000
Sep 20, 2010 11:19 AM
beat
May 6, 2010 02:38 PM
kennedyDAb18c5
Acura TSX
11
Jul 7, 2009 05:45 AM
DC2 to AP2
Suspension & Brakes
Sep 12, 2005 06:44 AM
