What kinda Engine Harness do i USE?
Old Apr 28, 2010 | 05:29 AM
ef2hondaboi's Avatar
Default What kinda Engine Harness do i USE?
I'm doing a B series swap in my 96 Civic Coupe DX. And was wondering what kinda Engine Harness should i use? And which one will work? Its a B Series VTEC?
Old Apr 28, 2010 | 05:59 AM
speedooo's Avatar
Default Re: What kinda Engine Harness do i USE?
96-98 civic ex...
Old Apr 28, 2010 | 06:05 AM
do i still have to wire up the vtec?
Originally Posted by speedooo
96-98 civic ex...
Old Apr 28, 2010 | 06:24 AM
nokturnal_munkeeboy's Avatar
it depends on what b series motor u use
Old Apr 28, 2010 | 06:39 AM
rick_rabies's Avatar
I'm not Rick!
use your factory one and wire vtec. (i have a vtec subharness for sale) just plug it in and put the pins in the ecu. pm if you want it $20shpd
Old Apr 28, 2010 | 06:48 AM
will that work? its just like OB1 then right? what kinda conversion harness should i use?
Old Apr 28, 2010 | 07:16 AM
speedooo's Avatar
You seem very confused...I'll break this down.
96-00 civics use a one piece engine harness that goes from the engine straight to the ecu. A B series vtec motor has all of the normal sensors along with a vtec pressure switch, vtec solenoid and a knock sensor. All of these commodities can be accommodated for with a 96-00 civic ex harness. You stated that your car is a 1996 civic dx, automatic at that. It is possible to use your stock harness but you will have to do the IACV 3 wire to 2 wire fix, add 2 wires for vtec and add knock sensor wiring....or you could just use a 96-98 civic ex engine harness.
To use an OBD1 ecu you will need a stepdown harness that plugs into the existing obd2 engine harness, making the obd1 ecu compatible.
shocker911
Feb 6, 2011 10:50 AM
Perkul8r
May 14, 2009 09:14 PM
eriknn
Jul 14, 2006 06:52 AM
Lmgrcivic
Jan 15, 2005 03:34 PM
EGTHU6
Jul 23, 2004 02:48 PM
