b18c5 all motor pick up only! CT 06340
$1700 found a bike i want
i have a Rdot stamped usdm b18c5 engine.
needs to be assembled!
Bottom end
bored .20 over
micropolished jdm b18c crank
stock rods (one rod needs to be replaced)
CP 12:5:1 compression pistons
unorthodox crank pulley
Head
Port and polished
3 angle valve job
skunk 2 tuner 2 cams (h08)
skunk 2 cam gears
Skunk 2 springs
Skunk 2 retainers
looking for $2000 FIRM.
wanted to build it but im looking to get a bike instead so im testing waters on this. if someone has cash ill sell it. no shipping pick up only. no window shoppers. and im not parting it out.
please do not lowball if you can find the parts cheaper then by all means im not stopping you from buying them.
i will have pictures up tommorrow after work (10 pm) i just wanted to see if i get any hits before hand.
call/text:860-326-9819
only if serious like i said no window shoppers
[IMG]
[/IMG]
Bottom end
bored .20 over
Head
Port and polished
3 angle valve job
skunk 2 cam gears
Skunk 2 springs
Skunk 2 retainers
[IMG]
[/IMG]
i know you said no part out but if you change your mind i will buy the crank and block i am in CT 06010. shoot me a price i am fair i am not a lowballer.
i would so do that if i did not already have 3 dohc vtec heads sittin here.
but if you change you mind i will come pick up the block and crank why you give me the word
