Black Housing knockoff headlight question
Old Sep 11, 2002 | 07:09 AM
m0t0rhead's Avatar
Default Black Housing knockoff headlight question
1. Has anyone purchased these from http://www.urbanimport.com ??
2. How easy to install ??
3. Are they exactly the same as the real 600$ ones ??
4. Also... they claim to use H4 for low beam.. and H1 for high beam.. can anyone confirm that to be correct ?
I was going to order it with new bulbs from Showoffusa.com...
[Modified by Escobar, 11:10 AM 9/11/2002]
Old Sep 11, 2002 | 08:22 AM
Razor's Avatar
Default Re: Black Housing knockoff headlight question (Escobar)
1. no
2. not really, you have to remove the front bumper to get to the bolts under the stock headlight
3. i wouldn't know, i have the real stanley SiR headlights, but people love the knockoffs(from what i heard)
4. yes this is true, but some people use the h1 for fogs lights(?).
for getting the knockoffs, you should buy them from http://www.autodynamic.com, best service.
Old Sep 11, 2002 | 09:21 AM
greensleeper's Avatar
1. yes. no problems.
2. front bumper and bumper bar have to come off. cake.
3. not the same. no leftward flare. they are DOT approved.
4. low beam housing has h4. high beam housing had h1. I've wired it to run normal low beam (low beam filament in h4). and then high beam setting is all three filaments!! really bright and really annoying to others. I will change it over to use H1 as fog when I find a yellow h1 bulb. but I have not found any yet.
Old Sep 11, 2002 | 12:20 PM
m0t0rhead's Avatar
Default Re: Black Housing knockoff headlight question (greensleeper)
What do you mean by "no leftward flare" ??
Old Sep 11, 2002 | 12:38 PM
93accordEX's Avatar
in Japan they drive on the other side of the road, so true JDM headlights will flare to the left to see road signs better and the side of the road, while in the US it will just blind people
Old Sep 11, 2002 | 01:13 PM
KCHybrid's Avatar
Default Re: Black Housing knockoff headlight question (93accordEX)
The real jdms do flare left kind of bad. Installing my hid's confirmed this.
Old Sep 11, 2002 | 02:02 PM
Accord_Munch's Avatar
Default Re: Black Housing knockoff headlight question (KCHybrid)
I am happy with my wanna b's ... they are just a pain the **** to adjust on the drivers side ...
Old Sep 11, 2002 | 04:38 PM
WhoNeedsVtec's Avatar
Default Re: Black Housing knockoff headlight question (Accord_Munch)
did anyone notice that autodynamic says low is h4, high is h3 and urbanimport says h4 low and h1 high. which one is correct?
Old Sep 11, 2002 | 05:12 PM
Razor's Avatar
Default Re: Black Housing knockoff headlight question (WhoNeedsVtec)
h4 low h1 high
Old Sep 11, 2002 | 06:59 PM
H22aInside's Avatar
Default Re: Black Housing knockoff headlight question (Razor)
for future note u do NOT have to remove ur front bumper! me and my friend pulled my headlights in 20 min with the bumper still on.
steps on how to remove headlights and keep the bumper on. 94-95 honda accord.
1. remove grill
2. unbolt 2 bolts at the top of the head light housing
3. unbolt 1 bolt by radiator, extension arm and swivle sockets recomended.
4. unbolt 1 bolt behind the corner light
5. unbolt the 1 bolt underneath headlight, u should be able to see it with the corner
off. u will need an extension arm to reach.
6. head light housing will be loose now. simply tilt housing up and remove the 4 screws holding the headlight to the head light housing.
7. lastly remove the big screw at the top of the headlight, this is one lug #$%# screw.
8. thank me for not having to go through the trouble of taking ur whole front bumper off.
and yes me and my friend have done this TWICE on my car. so i know it will work for the 94-95 accord and most likely the 96-97 accord too.
Old Sep 11, 2002 | 07:30 PM
raceACCORDingly's Avatar
Default Re: Black Housing knockoff headlight question (H22aInside)
im happy w/ my homemade stanley ones. costed me 5 bucks and a couple hrs.
Old Sep 11, 2002 | 09:02 PM
TypeSH's Avatar
Default Re: Black Housing knockoff headlight question (raceACCORDingly)
the knockoff set doesnt run a H4 high/low? what kind of adapters does the knockoff set come with?
Old Sep 11, 2002 | 09:55 PM
How would you wire it up to make H1 the fog?
401tuner
Mar 26, 2007 10:08 PM
mraza
Jun 22, 2006 04:30 PM
HipHop Head
May 9, 2006 01:14 PM
Briman2021
Dec 24, 2002 11:25 AM
djay86
Sep 19, 2002 06:55 PM
