1999 GSR Poorman's Type R Dyno
Hey everyone, Im posting my latest dyno sheet on my car. Its a 99 Gsr with a Poorman's Type R swap. Let me know what you guys think
Mods:
B16 Head
Mild Port n Polish
Dual Springs n Retainers
Blox Stage 2 Cams
Aem Cam gears
ITR Manifold
Blox 68mm TB
Aem short ram
DC 4-1 JDM Header
RC 440 Injectors
Walbro 255 fuel pump
GSR fuel rail
B18C1 Block
81mm CTR Pistons
Innovative motor mounts
GSR Tranny
ACT Streetlite Flywheel
ACT Heavy duty plate
ACT 6 Puck
Tokico Blue Shocks
Eibach springs
Custom 2.5 Exhaust
Dynomax muffler
225.4hp @ 8700
145lbs TQ
Mods:
B16 Head
Mild Port n Polish
Blox Stage 2 Cams
Aem Cam gears
ITR Manifold
Blox 68mm TB
Aem short ram
DC 4-1 JDM Header
RC 440 Injectors
GSR fuel rail
B18C1 Block
81mm CTR Pistons
GSR Tranny
ACT 6 Puck
Tokico Blue Shocks
Eibach springs
Custom 2.5 Exhaust
Dynomax muffler
225.4hp @ 8700
145lbs TQ
What was it tuned with? And do you have a before and after dyno. Strong numbers.
I was reading your parts list and couldn't see the graph at the same time and thought well just another 200whp build. But once I saw the graph Great job. If you are looking for more power a 3" CAI intake with a V-stack and a better header should get on your list.
its tuned with crome. Thanks, i was pretty happy with my numbers myself. Ya im thinking of upgrading my exhaust system and getting a v stack too. But Ill post some pics soon.
I went with tokico for now cause my shocks were going bad. But I know I gotta upgrade my suspension too. Kind of wish I just got some coilovers to begin with, but live and learn.
11.5:1 CR is what they told me (I thought it would be a bit higher.) But I have no issues so its pretty so far. on pump gas. I went with CTR just to sqeeze alittle more HP out.
Nothing so far for the block. Im working my suspension for now. I know I have to replace my DC header. I have HUGE dent on it. So im looking at maybe blox hi flow header. But well see, kind of hurting for cash at the moment since my upgrade.
im in the middle of collecting parts for my poor mans type r swap. My setup is going to be as follows:
b16 head port matched to intake manifold
b18c1 block
rs machine 82mm PR3 pistons
GSR Rods
crower dual valve springs
crower titanium retainers
blox type b cams
blox cam gears
68mm throttle body
PWJDM carbon fiber intake
rmf narrow style header
test pipe
2.5 in exhaust
Will be tuned on neptune
What compression would i be running with that setup? What crank should i use gsr,itr,ls??
Would i be able to lay down as much hp as you did?
b18c1 block
GSR Rods
blox type b cams
blox cam gears
68mm throttle body
test pipe
2.5 in exhaust
b18c1 block
GSR Rods
blox type b cams
blox cam gears
68mm throttle body
test pipe
2.5 in exhaust
b18c1 block
GSR Rods
blox type b cams
blox cam gears
68mm throttle body
test pipe
2.5 in exhaust
With that setup though your piston to deck height would be 0.035 which is kind of low. You want to be around 0.030 - 0.040 quench clearance. With a OEM head gasket at 0.026 you'll have around 0.061. It should work but I would use a different piston design. Maybe the JDM ITR (P73-00) pistons.
wow nice numbers bro!!!..ima tune my motor this Friday at Eriks racing with a similar set up just that i have the oversized CTR pistons HighEnd tri y's and a cometic .40" gasket so i could run it on pump gas..i hope to make sum hp like yours
b18c1 block
GSR Rods
blox type b cams
blox cam gears
68mm throttle body
test pipe
2.5 in exhaust
b18c1 block
GSR Rods
blox type b cams
blox cam gears
68mm throttle body
test pipe
2.5 in exhaust
Good luck on you're build
Post your results when its done.
Truthfully, if he wouldve used itr pistons he wouldn't have made the power he made...especially with those cams...that's why when ppl use itr's they usually don't get the power they're looking for..ctr's are the ****. But ppl are always bashing them but aren't getting the results with itr pistons and blox type b/s2s2 cams...these cams need high compression
Most power came from that port! iv had many high comp. b series motors and a few so called poor man type r setups, one of my motors was verry similar besides the cams and port work, im gonna say that port is what let you exceed past 215hp! i think a 3'' cai and a sk2 manifold would of freed up some more hp!!!
350hp ATI pro charged ITR coming soon.
ilovemyb16a
35
Oct 29, 2006 06:11 AM
