1st Gen B16A Bogging/Sputtering/Misfiring. HELP!
Old Apr 27, 2010 | 08:02 PM
AKAViRiZ's Avatar
Default 1st Gen B16A Bogging/Sputtering/Misfiring. HELP!
Alright so I bought this EG 4 months ago and I came across a problem.
I've been stuck on this for about 2 months already and I am so lost.
I have a FIRST GENERATION B16A Converted to OBD1.
What happens is when I first start it and run it cold, it seems fine(to a point).
When the car is warmed it starts to Bog and runs like it has no Power. When I start off in first, I feel no pull at all but once it hits about 2k - 3k it kicks right in and then there's a pull, after that I have to maintain my throttle at least 25% open to feel it actually pull and accelerate. When I'm at WOT, there's nothing. Sometimes if I'm light on the gas, it will shake or I guess you can say hesitate.
So Far Ive Replaced my Plugs, Plug Wires, Cap, Rotor, and Fuel Filter.
I have two ECU's, JDM PR3(P30), and Chipped P28 to run a B16A.
I have tried both and the problem still occurs.
I also have a Clogged Cat and I'm really leaning towards that or my Fuel Injectors, or my Dizzy.
What I also came across today is quite confusing to me.
I know JDM B16's Run 2 o2 sensors, and I'm only running one(Since I have an aftermarket header) its a 4 wire too. It is semi wire tucked.
I'm really lost now and I hope you guys can help me because i've tried everything I can think of.
Here's a picture of the o2 Wiring if it helps. Seems Sketchy to me being honest.
I unplugged that C16(the green plug right?) from the back on the longblock or head or w/e, i couldnt tell since the intake mani was in the way.
But I was gonna try and unplug the o2 sensor and see if itll fix my problem.
I couldnt find the plugs(except that one) so i just cut all four of those wires and it made my car run shakey and worse to me ill just re strip and connect them and use heatshrink.
HELP!
Old Apr 28, 2010 | 10:30 AM
AKAViRiZ's Avatar
Default Re: 1st Gen B16A Bogging/Sputtering/Misfiring. HELP!
Bump
Coffin22
Jul 5, 2011 07:41 PM
efinfroman
18
Aug 29, 2010 11:10 AM
.ShawnD.
17
Jul 2, 2002 06:57 PM
