Turbo LS VTEC overheating
Old Apr 27, 2010 | 06:07 PM
MrToasty's Avatar
Default Turbo LS VTEC overheating
I've got a problem with my 99 Civic with a Turbo LSVTEC and it will soon become an even bigger problem as the summer rolls in.
I'm monitoring the coolant temp with both a B&M Electronic Water Temp Gauge tapped at the cylinder head, replacing the stock temp sensor (to the gauge cluster) AND at the thermostat through Hondata S300.
Coolant temperature @ 70 mph without heater = 195 - 205
Coolant temperature @ 70 mpg with heater on full blast =190 - 200
Coolant temperature @ 0 to 50 mph without heater = 195 - 215+
Coolant temperature @ 0 to 50 mph with heater on full blast = 190 - 205
Engine specs:
Tuned by Slowmotionmotorsports
Fresh LS VTEC with plenty of forged goodies and the proper headgasket.
Turbo @ 18 psi.
C&R Aluminum Radiator
Brand new thermostat and gasket (180 degrees or so?)
Permacool 12" 1650 CFM radiator fan. Comes on at 180 degrees and 0 to 35 mph.
Everything seems to be functioning very well. No coolant loss, or bubbles in coolant. No oil leaks. Great compression. Everything is fresh. Engine only has 4,000 miles. Nothing wrong, except it seems to be running way too hot, and when the summer rolls in, i really don't want to be running this car (daily driver) with the windows up (raining outside) and the heater on full blast.
Anybody got any suggestions at all?
Also, i've noticed that if I cruise on the highway in 4th gear instead of 5th (which I only did for 20 seconds or so), the engine temps drop substantially... like to 185-190. Leads me to believe that the water pump is not flowing the coolant enough at lower RPMs.
Old Apr 27, 2010 | 06:09 PM
Chele's Avatar
Default Re: Turbo LS VTEC overheating
It may be your tune. Maybe your leaning out real bad.
Old Apr 27, 2010 | 06:59 PM
MrToasty's Avatar
On the freeway my AEM Wideband reads around 14.2 or a little less. Is that good or bad?
Old Apr 28, 2010 | 06:09 AM
dpetro1's Avatar
sounds like the typical turbo honda. add a fan shroud, get a better fan or both.
turbo blanket, wrapped mani, etc will also help reduce heatsoak
Old Apr 28, 2010 | 07:19 AM
MrToasty's Avatar
Really no room for the shroud. I'll try the header wrap first and then maybe purchase one of those expensive turbo socks.
Thanks.
Old Apr 28, 2010 | 07:36 AM
dpetro1's Avatar
any pics of the bay? a shroud is going to be your best bet.
also, turbo blankets can be had for $125, cheaper than a hg replacement or new engine build
Old Apr 28, 2010 | 09:50 AM
MrToasty's Avatar
I'll upload a picture of the engine bay tonight. Could my water pump be failing or something? Could it be anything else? Would an oil-cooler help?
Old Jun 14, 2010 | 04:52 PM
edstone83's Avatar
I would assume that during your build you rplc'd the water pump and oil pump. Did you?
I have a heating issue as well. I and running a percision 750 i/c which blocks my radiator and I think it is two main things. The 1/2 radiators and the air flow.
Here is a pic of mine and I am logging up to about 212 via my S300 and 205 via my autometer which is in the stock gauge sensor. I am fine at idle w/ the autometer reading 180 and the S300 reading 195.
Juicebox888
Mar 30, 2019 08:18 AM
shogun1552
Feb 12, 2013 07:38 PM
eglsvtech
May 3, 2008 11:57 AM
dkdjlf
Aug 14, 2003 10:34 AM
Albino Dragon
18
Apr 19, 2002 12:37 PM
