FS: Garrett 60 trim turbo, Venom, DP, Spoolin, B18
** EVERYTHING IS PRICED TO SELL QUICK!! **
i got a Garrett T3 T04E 60 trim turbo. has less than 300 miles, only seen 7lbs of boost. looking for bigger turbo. let me know what you have, trade plus cash? ZERO SHAFT PLAY
Specs:
-60 trim T04E compressor wheel with a max flow rate of 53 lb/min
-0.60 AR T04E compressor housing
-Good to 490 whp.
Turbine Specifications:
-stage 3 turbine wheel
-0.63 Turbine housing
-T3 5 bolt "Ford style" turbine discharge
-270 degree thrust bearing
$500
<br>
<br>
Also have some Venom 550cc High impedance injectors. SOLD!!!
<br>
<br>
Have a 5 Bolt Downpipe with straight 2 1/2" pipping all the way to the back for 94-01 integra. has 02 bung welded on for sensor. $200 obo
<br>
<br>
B18b Ls motor. has 130k miles, completely stock. piston rings are worn in cylinders number 1 and 3. passed smog though. ha. $300 complete long block with intake manifold, throttle body, and injectors.
<br>
<br>
Vtec Distributor. with MSD cap and Internals. $120
<br>
<br>
Specs:
-Good to 490 whp.
$500
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
bb6guy
Jun 7, 2010 03:28 PM
AnclyT
Jul 14, 2007 06:18 PM
